Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
Thread: biodiesel
  1. #21
    Join Date
    Apr 2005
    Looking out of the window
    Posts
    13,950
    Default Re: biodiesel
    In all seriousness, apparently Bio produces much less emissions and smoke than DERV, so even you AD41 users might be smog free [img]/forums/images/graemlins/grin.gif[/img] [img]/forums/images/graemlins/grin.gif[/img] [img]/forums/images/graemlins/grin.gif[/img] [img]/forums/images/graemlins/grin.gif[/img]
  2. #22
    Join Date
    Nov 2002
    Australia
    Posts
    5,903
    Have we had answers to the shelf-life question in a boat's tank? Also - are fuel pumps okay on it, as I've heard concerns about that raised....
    Rick
  3. #23
    Join Date
    Apr 2005
    Posts
    13,950
    Don't know about the fuel pumps, I've not heard that there is a problem if it is in a reasonably modern engine (post 1990 ish).
    Recommendation seems to be that 1/2 a tank of derv every now and then doesn't hurt. The main problem with logevity is that Bio will actually absorb water if left untreated over a period of time. Obviously not an issue in cars etc but in boats would be a problem.
    There is an additive avaible which stop the problem, and should be added to 'marine' bio diesel. Does add 3-5p per litre though [img]/forums/images/graemlins/frown.gif[/img]
  4. #24
    Join Date
    Oct 2006
    Lordswood, Chatham, Kent UK
    Posts
    43
    Rick
    Going by the car side of Bio (SVO), most bosch pumps are ok with it, but lucas pumps have problems with the seals swelling and too tight tolerances causing lubrication problems.
    Only other problem as i can see is it might make starting in the winter harder as the bio is a little bit thicker i think, but that could just bo on SVO.
    Tried an Escort van on 90% SVO 10% DERV and it ran no problems, even seemed quieter.
  5. #25
    Join Date
    Aug 2004
    Aberdeenshire (quite far from the Solent)
    Posts
    3,382
    Biodiesel isn't the same as Straight Vegetable Oil, is it?
    Tony S
  6. #26
    Join Date
    Nov 2006
    essex
    Posts
    8,159
    So we have red for a while longer,it would seem,but bio i hope is the way to go.Now need some experts at mercruiser,volvo,yanmar etc to have a serious look,if they want to keep sales up.If some minor adjustments are needed perhaps they could offer a bio conversion pack with manual!!!!
  7. #27
    Join Date
    Jul 2003
    sussex
    Posts
    1,568
    Volvo reckon that you can use it at a 5% mix only ie 5% bio to 95% road or red? I understand? [img]/forums/images/graemlins/frown.gif[/img]
  8. #28
    Join Date
    Apr 2005
    Posts
    13,950
    That is for warrenty on engines &lt;2 years old. TBH, Bio is fine in the engine to 100%, mine are out of VP warrenty, so they can go hang themselves. Same reason VP main dealers don't touch my boat. They tend to be expensive and cr<span style="color:black">ap</span>
  9. #29
    Join Date
    Aug 2004
    UK,Poole
    Posts
    32
    James
    Can you advise whether your Biodiesel adhears and tested to the EN14214(?) standard and do you have a list of fuel pumps/ marine engines that the diesel will work with.
    Based on the above are you happy to run 100% bio or a mix?
    From a delivery side what are the options and affects on price.
    Looked into making Bio myself, as I could make it pay in 18 months ( price of processor, chems and other equip ), but lack of space stopped me!
    Thanks in advance
  10. #30
    Join Date
    Aug 2004
    UK,Poole
    Posts
    32
    Robind
    As an example in Germany all pump diesel is 5% bio and 95% dino. 5% is a very safe mix and most likely not going to cause any issues to fuel pumps. I'm no engineer but newer engines run at much higher pressure and aren't good candidates for bio as they will clog up, especially when started cold.
    Older engines and I'm not sure what that means may be capable of running 100%.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
