Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2005
    Posts
    337
    Default Interior teak repair
    I know that there have been a few threads on here about teak repair but most of them seem to relate to exterior teak. Picture below shows interior teak on my (open) boat which now has quite a few patches on it. Does it need to be completely rubbed back and revarnished or is there a short cut?
    Cheers
    Jon
  2. #2
    LittleShip's Avatar
    LittleShip is offline Registered User
    Join Date
    Jul 2003
    Posts
    5,484
    Default Re: Interior teak repair
    No shortcuts....................strip it and then re-varnish. If you just rub down and varnish the marks will show. Welcome to the fun of woodwork! [img]/forums/images/graemlins/wink.gif[/img] [img]/forums/images/graemlins/laugh.gif[/img]
    Tom
  3. #3
    Join Date
    Aug 2005
    Posts
    337
    I was worried you'd say that!
  4. #4
    hlb's Avatar
    hlb is online now Registered User
    Join Date
    May 2001
    Posts
    25,380
    Make sure it's not that veneerial stuff and only .5mm thick. Dead easy to sand right through it.
  5. #5
    tcm is offline Registered User
    Join Date
    Jan 2002
    Posts
    22,500
    stripped back and revarnished s defintely the best way. Further, i wd say getting the piece out of the boat to work on is better. In fact, better than that would be to lift all the floor.
    I think you still need to use teak cleaner so you don't end up varnishing over the black bits of crud - it shd be sparkly clean before varnishing. Before that you need a stripper to get the old varnish off.
    With the varnishing itself, do it completely differently from the way in which you see most others doing it, cos most do it very badly indeed. The main thing to do is to pour the varnish you need to use, and reseal the tin and NOT continuously take varnish out with a brush - and dirt back into the tin.
    The best way to get a decent floor finish will be to probably to use a form roller.
  6. #6
    Join Date
    Aug 2005
    Posts
    337
    Thanks. Stupid question - I presume the light stripes are part of the floor itself i.e so when i strip it the stripes will still be there and can be revarnished?
  7. #7
    Yes, the light stripes are usually holly, the dark is teak
    2003 Windy Khamsin 34 for sale - YBW ref. AD-007-ESK
  8. #8
    Join Date
    Jan 2002
    Posts
    22,500
    quite so yes,the light and dark are teak and holly BUT they are very thin layers of teak and holly, probly on ply so go carefully.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
