Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Jun 2004
    Posts
    296
    Default Canal in sportscruiser
    Navigating the Forth & Clyde Canal and possibly Union Canal in a 25ft sportscrusier... Good idea or not?
    People seem to do this sort of thing in Canada (trent-severn waterway, etc) all the time.
    Obiously it would depend if I could get the boat to run slowly enough but I suppose I could change the prop to drop the tickover speed if necessary.
    Simon
  2. #2
    Join Date
    Oct 2001
    Posts
    2,619
    Default Re: Canal in sportscruiser
    i'm not too familiar with those canals but i had a small 'norman' running a large HP outboard on a couple of canals for a while.
    You need to check the minimum width of the canal (namely the locks) and the width of your boat. The narrowest locks in the UK will be too narrow for your boat.
    Regarding the engine.. my current 23ft with 200hp sterndrive was ok on the broads but a very small nudge on the throttle was showing over 4kts.
    Dropping the size of the prop a few sizes would surely help that no end.
    Other than that i think it should be fine..
    oh and check the air-draught of the bridges on the canals with that of your sports cruiser..
    regards,
    Nick
  3. #3
    mystique's Avatar
    mystique is offline Registered User
    Join Date
    Jan 2004
    Posts
    1,730
    And be careful where you moor - Canal towpaths tend to be a magnet for scrotes!!
    Statistically, one in seven dwarfs is Grumpy.
  4. #4
    Join Date
    Jun 2004
    Posts
    296
    Thx Nick
    I think the canal was originally built to accomodate small steamers, hence the idea in the first place, as I assumed width and bridge height would not be an issue. I'm bored at work so I'm checking the waterscape website now.
    Simon
  5. #5
    Join Date
    Sep 2005
    Posts
    336
    Been through the F&C with a 26' sailboat and no real problems. If you intend leaving the canal on the east side then you'll have to judge the tide correctly to pass under a bridge and pipes crossing the canal but still leave yourself clear of the bottom and enough time to get where your going. Download the http://www.waterscape.com/boating/pdfs?id=2590
    If you don't like something, change it.
    If you can't change it, change your attitude.
    Don't complain.
    Maya Angelou - US author & poet (1928 - )
    http://www.appletreebandb.co.uk
    http://www.bedandbreakfastprestwickayr.co.uk
  6. #6
    Join Date
    Oct 2001
    Posts
    2,619
    i agree on that one.. you do have to be careful with where you moor. Some parts of canals are fantastic quiet places. Others attract the Vicki Pollard gang...
  7. #7
    Alrob is offline Registered User
    Join Date
    Jul 2005
    Posts
    1,041
    met a couple last year who done the forth & clyde in a searay 280 - radar arch just made it through one bridge in particular.
    the best bit about the tale was when thay got to maryhill locks the lock-keepers told them not to stop & ushered them :through pronto [img]/forums/images/graemlins/laugh.gif[/img] [img]/forums/images/graemlins/laugh.gif[/img]
  8. #8
    Join Date
    Jul 2007
    Posts
    217
    i say a check your air draught as the forth and clyde
    has a drop lock,and several low road bridges.
    (steamers long gone) also mystique spot on
    not all canalside animals have 4 legs ,
    as for speed signs say 4knots,if your boat
    is ok at that speed now then unless you are
    intending to do a lot of canal cruising changing the
    set up for a trip that non stop takes 2 days or less
    seems hardly worth while.
    that said the falkirk wheel is well
    worth seeing.good picts to be had.
    old enough to know better, too old to care
  9. #9
    Join Date
    Jun 2001
    Posts
    5,211
    can you control the boat at low speeds. Biggest problem is entering the locks where you run the risk of clobbering the knuckles which have no problem doing damage to shiny gelcoat.
    Can you fit an outboard or would it be out of reach?????
    Eastern Scotland and beyond.
  10. #10
    Join Date
    Jun 2001
    Posts
    5,211
    Wrong.....
    The original canal was bridgeless.....well swing bridges...
    There are now numerous bridges and I believe the max air draft is 9 ft
    John
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
