Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Dec 2004
    Posts
    1,090
    Default coolant problem - any ideas?
    whilst out on a run round the bay we took the engines up to 24knots - tamd 63ps and suddenly the alarm went offand clouds of steam started to appear around the engine hatch.
    i closed down both engines straight away and steam was billowing out the hatch. it looks as though all the coolant dumped itself out of the engine. managed to get back on other engine ok.
    engineer out tomorrow but any ideaswhat would cause such a thing to happen?
    all engine temps ok prior to increasing speed and we were only at full speed for around 1 minute.
    thanks
  2. #2
    Join Date
    Feb 2006
    Posts
    143
    Default Re: coolant problem - any ideas?
    Happened to me last week, thermostate buckled in it's housing which stopped it from opening, check it out, might save you a lift out
    DEDICATED WELSHMAN!!
  3. #3
    Join Date
    Apr 2007
    Posts
    4,092
    Strange that could be impeller gone, is water flowing out of exhaust? stats dont usually play up on 63s steam was no doubt water coming out of filler cap under pressure, if the impeller has gone then you may have damaged the rubber exhaust hose as well, presume scott will sort it, off out now let me know how you get on back on forum tom nite, pm sent.
  4. #4
    Join Date
    May 2001
    Posts
    9,629
    Maybe a hose has come loose, happened to me once.
  5. #5
    Join Date
    Dec 2004
    Posts
    1,090
    thanks everyone . impeller theory sounds a good one. will let you know what we find. pretty scary when it happened so just calmling nerves with a strong drink:::::
  6. #6
    Seadee's Avatar
    Seadee is offline Registered User
    Join Date
    Mar 2007
    Posts
    141
    Bet ya a tenner (not a large Italian one ..) that it's your impeller. Happened to me last year. Shot down to a fishing mark, no problembos on the way down, left it to the last minute to get back for the bridge lift, shot back at top notch, ooops turkish bath off Lowestoft. Scarey isn't it. I found that the friendly Nanni serive engineer (who'd been to my boat two weeks previous) had noted "impeller OK" but when I removed it as part of the lengthy diagnosis it was "set" and even worse one of the vanes was set in the wrong direction. He'd never taken it out - only the £400 it cost me to give him a day out at the marina. Changed the impeller, topped up the coolant, been as good as gold ever since.
    Fret not - diesels are forgiving [img]/forums/images/graemlins/ooo.gif[/img]
    CD [img]/forums/images/graemlins/wink.gif[/img]
    Just a beer drinker with a fishing problem.
    Anglers Anonymous.
  7. #7
    RogerRat's Avatar
    RogerRat is offline Registered User
    Join Date
    Nov 2005
    Posts
    2,343
    Which engine Martyn???
    If it was the Starboard one that blew, I would go for impellar too, it's the hard one to get at. Port side is easy!
    If you're passing say Hi. It's probably Schnapps o'clock.
  8. #8
    Join Date
    Apr 2005
    Posts
    2,213
    Ah, that's a real shame Martyn.
    Hope you get it sorted quickly.
    Keep your sunny side up :-)
  9. #9
    peterandjeanette is offline Registered User
    Join Date
    Jun 2001
    Posts
    1,102
    Hi Martyn
    Have a look at water filter, see if there is water present and is not clogged. No doubt you checked water intake and have not picked up plastic bag, weed, the odd scuba diver etc. to block intake. Go for impeller next. Easy enough to check if on port engine, bit more difficult to get at on s'board.
    Doing our annual visit to Mallorca in October. You around then?
    Peter
    Be reasonable - see things my way.
  10. #10
    Join Date
    Dec 2004
    Posts
    1,090
    well 10 out of 10... it was the impeller; seems it had seperated from the metal barrell and stopped spinning. only replaced in january.
    now the engineer is trying to fit a new one on the starboard engine which is a little hard to get to.
    next job is try and stop alarm going off and see if any other damage such as gasket or exhaust.
    fingers crossed......
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
