I have a friend with a mobo, and we need to get some wires in behind the headlining to fit the telly and some other stuff. The headlining seems to be a one-piece moulding above the windscreen where we want to fit the bits. anyone know how to access without wrecking the place? Also running VHF extension to flybridge so need that access too. Thanks in anticipation, Bill
Results 1 to 7 of 7
25-09-07, 16:04 #1
Additional wiring in a prestige 32
Left hand down a bit.
25-09-07, 16:09 #2
- Join Date
- Aug 2007
- Posts
- 193
Re: Additional wiring in a prestige 32
Who supplied the boat to you?
They should have an aftersales department who although busy following the Southampton Boat Show should be able to furnish you with some information.
Ben
25-09-07, 16:32 #3
On the 32 Prestige there is a vertical channel covered in Vinyl just behind the drivers seat which goes up to the Flybridge. It is quite big, you can not miss it and it just pops off (the salesman showed me at SIBS when I asked the same question). There are also conduits in the roof lining but no idea how to get at them....and who says I do not look closely at boats!
Cheers
Paul [img]/forums/images/graemlins/smile.gif[/img]Boating is the only thing that keeps me sane!
25-09-07, 16:43 #4
Thanks guys, he got it from Prosser marine I think, so I'll direct him there. I can just envisage us knocking ŁKs off the value by graunching something that's always going to be in line of sight...
25-09-07, 16:46 #5
- Join Date
- Aug 2007
- Posts
- 193
Most of the panels can be replaced too, so if you do decide to use some 'force' to remove anything, make sure the part that isn't moving doesn't get damaged. The trim can all be replaced I believe, all be it at a cost.
Ben
25-09-07, 18:57 #6
Registered User
- Join Date
- Jan 2004
- Posts
- 1,340
The roof panel's on our Prestige 36 are held in place by "Big" Velcro pads, if you pull with some force they will come away.
"Open Another Bottle"
28-09-07, 10:36 #7
Thanks again guys. I hope this one's velcro too.
Bookmarks
