Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: SSB vs. Ham
  1. #11
    Join Date
    Mar 2002
    Posts
    214
    Default Thanks Roberto (nm)
    Thanks Roberto
    Wayne
  2. #12
    Gunfleet is offline Registered User
    Join Date
    Jan 2002
    Posts
    4,263
    Default Re: SSB vs. Ham
    Is it true you can have a problem with customs importing an 'opened up' Ham rig to the UK? I'd like to get a radio that covers both marine and Ham (am embarked on the ham route) for my boat. I really don't want two sets on the off chance I'd want to use the marine SSB in an emergency.
  3. #13
    Join Date
    May 2001
    Posts
    2,120
    John sent you a PM.
  4. #14
    Once again many, many thanks for all of your help. It looks as if I have got a lot of work to do but your posts have been most informative......thanks again
    Mark
  5. #15
    ham radio sets usually have a circuit in them which prevents them transmitting at frequencies outside the licensed ham radio bands, though they will receive across the full designed frequency range. open banding one is usually no more than a simple snip - a vasectomy for radios!. most uk second hand retail outlets seem prepared to do it on sets they sell, and since you might well need tech advice on setting up the set, i suggest you buy in the ukrather than the us
    what you will need are a transceiver, and aerial tuning unit, and the insulators to install in your backstay to form an aerail. mind you, if i were installing mine again, i would simply hoist an aerial on a haliard when i wanted to use it, rather than increase the risk of backstay failure. some people will say "what about an emergency". I would rather place my faith in a decent epirb since hf propagation is not always reliable.
    most of the radio nets that will be of use to you are ham nets, and you wont get a response on these without a callsign. however, the license now is much easier - the once feared morse is a doddle at 5wpm, and is a surprisingly interesting thing once you get into it.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
