Results 1 to 8 of 8
  1. #1
    Default Lost Volvo Penta Keys
    Hi I wondered if anyone knows the procedure for obtaining replacement Volvo Penta KAD 44 keys? The boat is currently docked in Spain and one of the keys has gone missing, the boat was recently purchased from the UK but arrived with only 1 set onboard.
    Thanks in advance
  2. #2
    Join Date
    Sep 2005
    Posts
    4,033
    Default Re: Lost Volvo Penta Keys
    Cheapest way to solve this will be to buy a replacement barrel and keys off ebay - they do come up fairly frequently.
    cheers
    Jimmy
  3. #3
    Join Date
    Sep 2003
    Posts
    309
    thats annoying, how did you lose them? did they go in the drink? as jimmy above says, i think ebay for new cylinder and key is a good start. good luck!
  4. #4
    mont is offline Registered User
    Join Date
    Nov 2005
    Posts
    296
    On a similar thread ....
    Could do with getting some spare VP ignition keys ( 2 x 2 ) c.1993 panel.
    Anyone any ideas on cost / availability or alternative sources ?
  5. #5
    DavidJ's Avatar
    DavidJ is offline Registered User
    Join Date
    Jun 2001
    Posts
    3,267
    Have a look through your paperwork for numbers like 0ISBN they are Volvo key numbers and Volvo should get one to you in a couple of days.
    When new the boat would have had 2 sets of keys. Contact the broker and if possible original owner.
    Failing all that ...new barrel as suggested.
    Huge bad luck though.
  6. #6
    DavidJ's Avatar
    Join Date
    Jun 2001
    Posts
    3,267
    A couple of years back someone on this forum suggested that they were the same as the car. Haven't tested it out but worth a try....report back please if successful.
  7. #7
    Join Date
    Nov 2001
    Posts
    1,221
    If you get stuck, or a temporary solution is to remove the barrel and drill out one pin, this allows you to remove the tumblers, then any volvo key including old type [144/244] car ignition keys will operate the switch.
  8. #8
    Join Date
    Nov 2001
    Posts
    1,542
    I think that without the numbers new switches will be the volvo answer
    you can buy sets of 2 or 4 switches all with the same keys and are less expensive than individual switches
    why is it that boatbuilders dont fit them ?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
