Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Sep 2007
    Posts
    554
    Default Can the shrouds be used as a radio aerial ?
    I am now down in the bowels of my Folkboat "rewiring" everything I can find. " Hera" is full of long redundant wiring, but today I followed back a cable that was attached to a shroud plate ... it looks very much like a radio aerial. Its not the VHF cable as that has been removed from the mast and replaced with new. So can the shrouds be used as an aerial ?
    Also anyone know where I can by a "choc block" connector "Maplins" dont seem to have one ?
    Another nice day here in Scotty ...but the winds keeping the temp. down.
    Mike.
    I'm happy to be free as the wind as the wind is tax free, so far.
  2. #2
    Join Date
    Feb 2005
    Posts
    451
    Default Re: Can the shrouds be used as a radio aerial ?
    I have this arrangement on my GK24, the shrouds act as a good broadcast radio aerial.
    This works well with my vintage 1970's Sharp car stereo I fitted.
    However, with a modern MP3/CD radio combo, the radio was useless and unstable with wierd whistles and burbles on Radio 2, the only station it could recieve.
    So I went back to the old stereo - after all its more in keeping with the 1979 boat.
    As for chocolate blocks, B&Q sells them for various prices from 99p for two made-in-china versions. Searching the electrical shelves nearby shows others priced higher.
    Otherwise try an electrical/builders wholesaler.
    It is held that a good crimped connection is probably more secure, but I have made some crimps that are worse than a chocolate block connection, usually with the wrong sized wire involved.
  3. #3
    Join Date
    Sep 2007
    Posts
    554
    Thanks Mike Will keep the old radio aerial as a back up.
    Re the choc block ..... (new instalation) I had to cut the Radar cable ...and others on the site advised using a choc block ..........nothing in my local B&Q but will check again tomorrow.
    Mike
  4. #4
    oldharry's Avatar
    oldharry is offline Registered User
    Join Date
    May 2001
    Posts
    6,682
    Trouble with the B&Q cheapos is the metal screws rust instantly in damp, seize up and the rust pushes the wire away and breaks contact..... better quality ones have plated metal parts which protects them in damp, but not wet, conditions.
    Is Conservation for wildlife or conservationists?
    http://boatownersresponse.org.uk
  5. #5
    alan17 is offline Registered User
    Location : Home near Stansted Airport Boat at Burnham yacht harbour
    Join Date
    Mar 2006
    Posts
    701
    Use choc blocks with a metel blade insert. They are much kinder to the wire than the simple screw type. They are available from Index Marine and most chandlers. To prevent corrosion coat with silicone grease.
  6. #6
    Join Date
    Jun 2006
    Posts
    2,751
    Mike
    It sounds to me like you and F_O_G are getting lines crossed as regarding choc blocks, he means block connectors and It sounds like you mean something else.
  7. #7
    Join Date
    Mar 2008
    Posts
    106
    A good tip with chocbloks is to tin all the wires first with a soldering iron. A lasting connection is guaranteed.
    I must go down to the sea again, the lonely sea and sky.
    I left my vest and pants there, I wonder if theyre dry?
  8. #8
    TonyS is offline Registered User
    Join Date
    Feb 2003
    Posts
    554
    The shrouds are a much better Navtex aerial than the thing that they sell that sits on the pushpit until it gets broken off!
    Tony
  9. #9
    Beadle's Avatar
    Beadle is offline Registered User
    Location : Rural Nth Yorks - 2 miles from bus stop, 8 miles from station.
    Join Date
    Aug 2007
    Posts
    6,627
    You don't say what radio and whether transmitting or just receive.
    Certainly you can use the shrouds, but not advisable for transmitting, all of the metal bits of the rigging would be live with RF which is not recommended.
    Should make a decent receive aerial, but will be best if you connect well up the back stay or shroud rather than the bottom of the wire.
    Dunno what a "chocolate block" is but I would use a couple of Jubulee type clips, solder the end of the wire and connect it with the end of the wire pointing downwards. A spot of waterproof sealer will complete the fitting.
    If you can bear to hear the truth you've spoken
    Twisted by knaves to make a trap for fools,
  10. #10
    markdj is offline Registered User
    Join Date
    Jul 2002
    Posts
    1,154
    For receiving only yes, but use a ring type crimp terminal and tin the wire and use some glue filled heat shrink to prevent water ingress. Any moistre at all and the copper quickly decays.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
