Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2007
    Romsey, Hants
    Posts
    1,131
    Default Raystar 120 GPS lithium battery anyone replaced one?
    I posted a few days ago about my intermittently operating GPS. A tour of older USA threads shows that there is a history of these units failing - apparently a bad batch were produced a few years ago, unclear when. Also is that they have a lithium battery in them similar to that on a PC board and it is unclear if these pack up after a while and might be the source of the problem. Has anyone here opened up their aerial and replaced the battery - is it easy to do, did it make a difference?
    BTW, Hardy and Raymarine both recommended an upgrade to a 125 unit which is fine if you want to spend a couple of hundred quid on something that should work already!
  2. #2
    Join Date
    Feb 2004
    West London/Gosport
    Posts
    5,541
    Default Re: Raystar 120 GPS lithium battery anyone replaced one?
    I've opened up the aerial and replaced the cable. Easy enough but I don't remember seeing a battery.
    (The previous cable just had too many joins.)
  3. #3
    Join Date
    Jan 2003
    Clyde
    Posts
    6,696
    No but I have replaced one on a Garmin GPS12, Be very careful if soldering. Batteries are of a very common type. SEE THIS POST
  4. #4
    Join Date
    Aug 2001
    Singapore
    Posts
    1,427
    There is a stock lithium battery inside. Depending on the age of your GPS it is either just slotted in (easy to replace) or spotwelded to SS leads (A bitch to get off). For the later I recommend to use a small (2mm) drill bit and drill the "spotweld" out . that leaves you with the two SS fins to slot a new battery in between (observe polarity!!). Secure it with a blob of silicone.
    Worked fine for me.
  5. #5
    Join Date
    Oct 2007
    Romsey, Hants
    Posts
    1,131
    Thanks Talulah - you say you opened it up - can I ask how - does the top of the mushroom dome just crew off?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
