Results 1 to 8 of 8
  1. #1
    Join Date
    Oct 2006
    St Neots
    Posts
    145
    Default Navtex on Raymarine plotter
    Hi Folks
    Does anybody have any experience of interfacing a Raymarine plotter with a Navtex unit? The plotter is capable of showing Navtex messages via NMEA.#
    Cheers,
    John
  2. #2
    Join Date
    Jan 2004
    Brixham - Devon - UK
    Posts
    17
    Default Re: Navtex on Raymarine plotter
    Yes I have done it a few times the Nasa engine works well you also need to update the C or E to ver. 4.29 and change the nmea input to Navtex if you are in the South west I can do it for you
  3. #3
    Join Date
    Oct 2005
    A long way from my boat! :(
    Posts
    10,057
    Sounds like you can't do both AIS and Navtext at the same time on the Raymarine.
    There's no reason why you shouldn't be able to do this but Raymarine just point blank refuses to implement serial to TCP/IP on their systems or multiple protocols simultaneously on the single port they have available, and their development team seem to be devoid of any interest in reacting to suggestions.
    If Raymarine do go under perhaps someone with a bit of vision might take over, somehow I doubt it though.
    sorry - rant mode over.
    ( yes I know AIS is 38k4 and navtext is usually 9600 but that bit is easy to get around )
    Preveza Sailing Group @PrevezaSailing
    https://www.facebook.com/PrevezaSailing/
  4. #4
    Join Date
    May 2001
    UK East Coast
    Posts
    32,220
    [/ QUOTE ]Wouldn't a simple multiplexer enable both AIS and Navtex simultaneously?
  5. #5
    Join Date
    Oct 2005
    Posts
    10,057
    I think if you put the e series AIS mode ( ses port to 38k4 ) it forgets how to read Navtex and vica versa
  6. #6
    Join Date
    May 2001
    UK East Coast
    Posts
    32,220
    Surely it's possible to input AIS and Navtex data to a multiplexer, then output to a C/E series?
  7. #7
    Join Date
    Oct 2006
    St Neots
    Posts
    145
    Cheers for that.
    I am looking to next year, and am updating the software in my plotters as new verions become available, but thanks for the offer of the update.
    Regards,
    John
  8. #8
    Join Date
    May 2009
    Nether Wallop
    Posts
    131
    Looks like a bit of confusion has sprung up here between AIS and Navtex.
    The Raymarine units will accept one of NMEA, AIS or NAVTEX on their NMEA port - you specify which in the configuration.
    Although there is an NMEA style standard for NAVTEX receivers, this is only currently used by commercial units such as the Furuno NX-700 and McMurdo NAV-7. Raymarine support a simple data stream at either 4800 or 9600bps, which means that they will work with the Silva N15, NASA Navtex Engine, McMurdo NAV-5 and NAV-6 and Furuno NX-300 navtex receivers. They will not work with the NASA PC Navtex Pro, Furuno NX-700 or McMurdo NAV-7.
    Tim Thornton
    TeamSurv www.teamurv.com
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
