Results 1 to 4 of 4
  1. #1
    Join Date
    Jul 2002
    Strangford Lough, Northern Ireland
    Posts
    1,240
    Default Anode for Nanni - where does it go?
    Does anyone know where the anode for a Nanni diesel 5.250 tdi goes?
    According to the website, it needs changed/checked every two years but I can't find any manual for the engine. I've looked about the engine and heat exchanger but can't see where it should go.
    Any help is much appreciated.
  2. #2
    Join Date
    May 2003
    Here or there
    Posts
    74,558
    Default
    Quote Originally Posted by markdj View Post
    contact
    http://www.peachment.co.uk'
    Brexit: ‘taking back’ what we had never lost, in order to lose everything we had...
  3. #3
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    41,251
    Default
    I cannot find a manual for that engine but in the couple I looked at there is an anode is in the water injector exhaust elbow.
    A look at the manuals that are on the Nanni website may give some indication.
  4. #4
    Join Date
    Jul 2002
    Posts
    1,240
    Default
    Many thanks for the replies.
    On the exhaust elbow there is a right angle connection for water which goes down to the shaft seal so it's possible this is where the anode went.
    Is there any other place I could put an anode or should I consider putting the anode back in (if this is where it went) and supplying the water for the shaft bearing some other way?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
