Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Mar 2009
    Dalgarven, Ayrshire
    Posts
    548
    Default
    Hi Puff etc
    I like the pook of your head lining on your Centaur. What is it?
    73s de
    Johnth
  2. #12
    Join Date
    Apr 2002
    Cornwall
    Posts
    7,640
    Default
    Quote Originally Posted by Sea_Spray View Post
    Thanks for the offer, but I've ordered one of these ebay remotes to see how good/cr*p they are...
    Have you checked the rating for it ? cannot see it stated anywhere.
    Brian
    Kddpowercentre VASR charge
  3. #13
    Join Date
    Nov 2007
    Kingdom of Fife
    Posts
    5,933
    Default
    Quote Originally Posted by halcyon View Post
    Brian
    Unlikely to be that much of a problem as you are only switching relays and that is what they are designed for. I would certainly have more care buying the relays themselves.
    Peter
  4. #14
    Join Date
    Mar 2005
    Pembrokeshire !
    Posts
    822
    Default
    I've got one of those from ebay - works fine. Reasonably splash proof - but certainly not waterproof.
    Has worked fine for the last 2 years
    P.S. I do have deck mounted foot switches in the bow - but seeing as I sail shorthanded a lot - the wireless remote gets most of the use
  5. #15
    Join Date
    May 2001
    Posts
    14,081
    Default
    Quote Originally Posted by JohnTH View Post
    Hi Puff etc
    73s de
    Johnth
    It's non-woven carpeting as used on the insides of 'cheap' speedboats.
    Basically, you glue strips of wood directly to the fibreglass using thickened resin and short self-tappers. The panels are 3mm ordinary plywood that were given several coats of cheap acrylic 'varnish' (Burgess, used simply because it was available due to a miscalculation at work, many years ago: hence, cheap) applied wet-on-wet. The panels were cut to fit on the wooden strips, the two at the side overlapping the central one. The carpeting is stuck to the panels with impact adhesive, the type that is used for Formica or similar laminates. A two-inch excess allows the fabric to be taken round to cover the edges and is also stuck with the Formica adhesive.
    The panels are fixed to the wooden strips with stainless self-tappers . The pozidrive / Phillips countersunk heads blend quite well into the grey carpeting. They are very thin screws because there are so many of them - one every five inches or so - and the panels are not heavy.
    I did the work some nine years ago. There are more photos on the Westerly Owners Yahoo group, a mine of knowledge on just about anything to do with Westerly boats. PM if you need more information.
    http://groups.yahoo.com/group/Wester...98678/pic/list
  6. #16
    Join Date
    Mar 2009
    Dalgarven, Ayrshire
    Posts
    548
    Default
    Great, I have got the picture from the post and, from your description, should be able to sort something out.
    Many thanks, I expect that I should join the rest of the Westerly clan sometime.
    73s de
    Johnth
  7. #17
    Join Date
    Nov 2003
    Posts
    28,184
    Default
    73s de
    Johnth
    Hawke House maine sell that carpet and the spray adhesive that actually works.
    I did my bulkhead with it in one piece.
    'East Coast Pilot' at www.eastcoastpilot.com 4th Edition now available......
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
