Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    Jan 2004
    Posts
    315
    Default how to clean the bimini canvas.
    Its getting a bit green.
    Any ideas on how to clean it.I saw people use white vinager and diluted bleach on the deck, but dont want to damage the canvas.
    What do I use to re waterproof it after its clean?
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    42,716
  3. #3
    Join Date
    Sep 2007
    Over-wintering in Lagos, Portugal (with Tethys :-) )
    Posts
    88
    Default
    We used Boracol (bought from http://www.acslimited.co.uk - excellent and friendly next day service, no commercial connection other than being a satisfied customer, twice) on our sprayhood then re-proofed with Fabsil (available from camping shops) with superb results. It even got most of the black spotting out of the webbing tie downs. The sprayhood, now 7 years old, has been replaced, although only because we've had other new canvas (stackpack, binnacle cover and bimini) in preparation for our cruising life and we are keeping the old sprayhood for use over winters.
  4. #4
    Join Date
    Sep 2008
    Cambridge/Pin Mill
    Posts
    872
    Default
    Opinion vary but I clean my acrylic canvas sprayhood/sailcover/dodgers with a jetwasher - but put them on grass. Wouldn't like to think what would happen on concrete... This removes all the green stuff and brings them up like new. Never had any other stains to remove but interested to see CornishSailor's recommendation...
    Would also recommend proofing with Fabsil - I use the Fabsil Gold and yes, buy it from a camping shop as it's much cheaper: -
    http://www.camping-online.co.uk/wate...bsil-gold.html
    I find 1 litre does the sprayhood and sail cover with a little left over, but it would depend how you apply it. I use rubber gloves and a hard sponge but you can brush it on. And don't do it in a confined space!
  5. #5
    Join Date
    Jan 2004
    Posts
    17,660
    Default
    I another post over the weekend, warm water, washing up liquid and a little bleach was suggested for cleaning off algee on the boat, what would that do to a spray hood or bimini?
    'The will of the people' = The will of a few fanatics who have duped the unsuspecting.
  6. #6
    Join Date
    Jan 2005
    Now in Brixham
    Posts
    482
    Default
    Depends on the fabric to a degree. The following instuctions I used for Sunbrella material;
    Heavy cleaning for stubborn stains and mildew
    Sunbrella® Shade fabric does not promote mildew growth, however, mildew may grow on dirt and other foreign substances that are not removed from the fabric. To clean mildew, or other stubborn stains:
    •Four ounces (1/2 cup) of chlorine bleach.
    •Two ounces (1/4 cup) of mild soap and/or detergent.
    •One gallon of water.
    •Carefully clean with soft bristle brush.
    •Allow mixture to soak into the fabric for up to 15 minutes.
    •Rinse thoroughly until all soap residue is removed.
    •Air dry.
    •Repeat if necessary.
    •Re-treatment of fabric for water and stain resistance will be necessary.
    Remember to protect the area around your Sunbrella if using a bleach solution. Carpet or other fabrics that are not Sunbrella may have an adverse reaction to the bleach.
    If a boat cover is suitable in size for a washing machine, these steps should be followed:
    •Use mild soap and/or detergent.
    •For heavier stains add 1/2 cup of bleach to wash.
    •Wash and rinse in cold water.
    •Air dry. Never apply heat to Sunbrella.
    •Re-treatment for water and stain resistance will be necessary after machine washing.
    Re-treating the fabric
    As part of the finishing process, Sunbrella® Shade fabrics are treated with a fluorocarbon finish, which enhances water repellency. This finish is designed to last for several years, but must be replenished after a thorough cleaning. Based on test results, Glen Raven recommends 303 High Tech Fabric Guard™ as the preferred re-treatment product for Sunbrella fabrics. Fabrics should be re-treated after thorough cleaning or after five years of use.
    For more information on re-treatment products, please visit www.303products.com.
    * Synthetic fabric heat settings normally do not exceed 150°F/66°C.
    Applying 303 High Tech Fabric Guard
    303 should be applied to Sunbrella® Shade fabrics after each thorough cleaning, which typically removes the original finish and reduces the fabric’s water repellency.
    •Clean Sunbrella using one of the cleaning methods.
    •Allow Sunbrella to completely air dry.
    •Apply 303 Fabric Guard in a well ventilated area following instructions on the container.
    •Apply 303 in a thin, even coat and allow fabric to dry completely.
    •Apply a second thin, even coating of 303. (Two light coatings are more effective in restoring fabric water resistance than a single heavy coating. A 15-ounce bottle provides coverage of up to 50 square feet of fabric.)
  7. #7
    Join Date
    Jan 2004
    Posts
    17,660
    Default
    I stopped off at C&J marine earlier this afternoon. They advise against using any bleach or even detergent to clean canvas products, apparently its the stitching that is the problem. They sell Renovo, so I suspect that is as good as a recommendation. But a sprayhood will need reproofing after.
  8. #8
    Join Date
    Oct 2009
    South Coast UK
    Posts
    2,860
    Default
    Mine's a bit more far gone than yours by the sounds of it, I'm going to try Polycell 3 in 1 mould killer, sprayed on and left for a couple of days, followed by a good rinse, wash, rinse again, dry, reproof with Fabsil. Read a number of posts where people had used the 3 in 1 with good results...
  9. #9
    Join Date
    Jun 2005
    I'm in London / Boat in Solent
    Posts
    857
    Default
    Quote Originally Posted by CornishSailor View Post
    Hi CornishSailor
    Did you brush the boracol on and then just leave it to dry or brush on and later wash it off please? I've got lots of boracol left as I use it on the teak deck so would be great to put it to sprayhood demoulding duty too.
  10. #10
    Join Date
    Feb 2010
    st lawrence bay /essex
    Posts
    396
    Default
    5 litres of fabsil on ebay for £30 and £5 delivery.knick the the ol ladies spray bottles from under the sink.voila
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
