Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Join Date
    Mar 2008
    Argyll
    Posts
    5,359
    Default
    Quote Originally Posted by twinkeel View Post
    Lots of good feedback here
    Looking hard at the Dyneema solution but am a bit worried by the comment regarding UV degradation.
    Is it really only good for a couple of seasons ?
    Anyone got any tricks for protecting it ( Eg. use mousing line attached to halyard shackle so that the Dyneema can be withdrawn into the mast when not in use ??
    Thanks to all
    Racers strip off the coat to reduce weight and windage, just leave the coat on, its purpose is to cover the core where the strength is.
  2. #22
    Join Date
    Jan 2010
    Strangford Northern Ireland
    Posts
    1,021
    Default
    Quote Originally Posted by Quandary View Post
    yea that was my point about keeping it covered ie the outer coating in place as a previous formite had mentioned stripped dynema.
    i have then had it hard racing for 6 years without problems
  3. #23
    Join Date
    Aug 2009
    Scotland.
    Posts
    12,533
    Default Braid On Braid Is Good Enough
    I use braid on braid on my boat and have used braid on braid on a charter fleet as well. Adjusting the Halyard when sailing is pretty standard practice and upwind performance has never been limited because of braid on braid. It lasts years as well.
    I would recommend that you go for brain on braid.
  4. #24
    Join Date
    May 2003
    Here or there
    Posts
    74,565
    Default
    Quote Originally Posted by BlowingOldBoots View Post
    Brexit: ‘taking back’ what we had never lost, in order to lose everything we had...
  5. #25
    Join Date
    Jan 2006
    Derbyshire
    Posts
    686
    Default
    These people are very good (used them last year) here is a good rope for halyards: http://www.outdoorxscape.co.uk/store...ope/p_134.html
  6. #26
    Join Date
    Nov 2009
    everywhere
    Posts
    13,410
    Default
    Quote Originally Posted by idpnd View Post
    There used to be halyards before dyneema correct? Pre-stretched polyester perhaps?
    Yes - they were wire. Unless you werent too bothered about sail performance.
  7. #27
    Join Date
    May 2003
    Here or there
    Posts
    74,565
    Default
    Quote Originally Posted by Bosun Higgs View Post
    3 strand pre-stretched used to be the norm for cruising boats 30 yrs ago
    with wire to braid for racing
  8. #28
    Join Date
    Feb 2006
    Cheshire
    Posts
    69
    Default
    Quote Originally Posted by Finbar View Post
    In the old days in your size of boat halyards were generally wire, spliced to polyester rope at the working end for handling. Today I would definitely go with dyneema, you can buy 10mm for £2.50 per metre at
    http://www.ropecellar.com/ChandleryForSale.asp
    I have bought from them in the past and had good service
    For regular racing use dyneema certainly, but for cruising a good polyester braid-on-braid with low stretch figures performs well and is much cheaper. My stock brand is 2.2% at 20% of break load, anything similar or better would be good. For halyards don't be tempted downsize for economy, you'll increase the stretch by about the sq of the difference in diameter.
    Barry at Boatropes boatropes@barryedwards.co.uk 01606 888154
  9. #29
    Join Date
    Jun 2001
    Posts
    10,361
    Default
    Boat is 30ft with a tall rig (40ft luff)
    Main halyard needs replacing and am confused by conflicting advice from chandlers.
    Some say Liros braid on braid
    Others say low stretch polyester with braided outer
    What do people think ?
    Dyneema - my spinnaker halyard is 20 years old and still utterly sound (and that is in the Med).
    An alternative is Vectran - not quite as strong but slightly less stretch.
    For a main the size of yours (it's similar to mine) braid on braid, even is prestretched will be a very cheapskate and unsatisfactory solution.
    My original halyard was Kevlar - that does suffer from UV degradation as well as fatigue - its only advantage was its lack of stretch.
  10. #30
    Join Date
    Feb 2006
    Cheshire
    Posts
    69
    Default
    Quote Originally Posted by charles_reed View Post
    .........braid on braid, even if prestretched will be a very cheapskate and unsatisfactory solution.....
    If that is so can someone please explain how my customer with a Storm 33 rerigged his main halyard and all other running rigging with my brand of braid-on-braid and achieved 3rd in class round the Isle of Wight this year? I offered it for cruising rather than racing but he doesn't regard his purchase as "cheapskate".
    It would be more helpful if contributors could offer their advice from their own perspective whether cruising or racing.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
