Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    moodyNick's Avatar
    moodyNick is offline Registered User
    Join Date
    Apr 2003
    Posts
    10,946
    Default
    Deliberately picking up on this old thread as I have been planning to buy one of these units.
    I am wondering what happens to the VHF signal if the Comar unit fails or is depowered. Does it fallback to a direct connection?
    Now I am also concerned about this S/N ratio issue.
    Has anybody any further news?
  2. #12
    Join Date
    Nov 2004
    Posts
    17,607
    Default
    Don't know about the multi - we have the normal dual channel comar engine on a dedicated antenna and very happy with it ... never been happy with splitters of any sort .. hopefully it's an unjustified prejudice!
  3. #13
    aluijten's Avatar
    aluijten is offline Registered User
    Join Date
    Oct 2004
    Posts
    957
    Default
    Quote Originally Posted by MoodyNick View Post
    In this case, as soon as you start transmitting with your VHF you'll fry the receivers in the AIS receiver. After that it's anyone's guess what happens next. Ideally nothing and the VHF will still work, worst case the RF-amplifier is shorted out and is fried as well. You must make sure the power to the splitter is always present when the VHF is powered on.
    It's a attractive solution to use a splitter in the effort to install but one that should be avoided if possible. As usual with these solutions it'll work under normal circumstances, but when the sh*t hits the fan these systems will always find a reason to fail.
  4. #14
    maxi77's Avatar
    maxi77 is online now Registered User
    Join Date
    Nov 2007
    Posts
    5,205
    Default
    I have the same unit but with a dedicated aerial. I have found the Comar support excellent and a faulty unit was replaced without any quibble
    Peter
  5. #15
    BlueChip's Avatar
    BlueChip is online now Registered User
    Join Date
    Aug 2004
    Posts
    3,401
    Default
    I posted the original message with the problem. Since then Comar replaced the unit and I had the same problems with the new one. I had the VHF antenna and radio checked out and all are ok, so I never got to the bottom of the problem. I now use the Comar with a dedicated pushpit antenna and it works fine but that rather defeats the point of buying that particular model with the antenna sharing.
  6. #16
    moodyNick's Avatar
    Join Date
    Apr 2003
    Posts
    10,946
    Default
    Quote Originally Posted by aluijten View Post
    That depends on the design of the unit, which is what I am trying to find out.
    I have always been concerned about separate splitters and avoided them. Now I am trying to avoid the hassle of a second antenna installation, so want to find out more.
  7. #17
    moodyNick's Avatar
    Join Date
    Apr 2003
    Posts
    10,946
    Default
    Quote Originally Posted by BlueChip View Post
    Thanks BlueChip, that's a great help !!
  8. #18
    Join Date
    Aug 2001
    Posts
    1,317
    Default AIS noise?
    The AIS specs call for a dedicated antenna. All so called splitter solutions are NOT to be used. Why spend top $ on an AIS, save a few bucks on a separate antenna and compromise both AIS AND VHF.
    If cost were the issue I'd rather use a dedicated coat hanger for the AIS than sharing an antenna.
  9. #19
    Join Date
    Oct 2004
    Posts
    1,825
    Default
    I have a COMAR too and it saw us safely from Turkey to India.
    The one piece of advice I was told when researching this subject was NEVER SPLIT THE VHF AERIAL, no matter what gizmos you are told will do the job.
    With this in mind I ran two independent aerials for each AIS and VHF down my rigging and through the deck. I used self-amalgamating tape around the cables to the rigging and whilst it wasn't the prettiest solution I have never had a problem (actually, you barely notice it). Since we were about to embark on a long journey through busy waters it was a case of opting for a practical solution, and this was it.
    Whilst you already know that separate aerials is ideal but not practical my advice is run separate aerials no matter how difficult or ugly they are to install.
    Sorry if this isn't solid technical advice, it's just my personal experience.
  10. #20
    aluijten's Avatar
    Join Date
    Oct 2004
    Posts
    957
    Default
    Quote Originally Posted by demonboy View Post
    Does this imply you've mounted both antennas in the top of the mast next to each other?
    If so, I'm surprised the AIS receiver hasn't blown because of the power emitted from the VHF when sending.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
