Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Feb 2006
    Posts
    477
    Default approxamate cost outboard service
    does anyone know how much it costs to have a 15hp johnson serviced ar runs ok but doesnt pump water its about 15 yrs o;d
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    40,667
    Default
    Quote Originally Posted by danielle View Post
    A basic service is one thing ... vitually nothing that the majority of people could do themselves in an hour or so.
    Sorting out why it does not pump water or why there is water in the gear oil is something else. That's where the costs will start to be incurred.
    Some mechanics will not touch older engines.
  3. #3
    Join Date
    Nov 2003
    Posts
    28,182
    Default
    where are you located?
    'East Coast Pilot' at www.eastcoastpilot.com 4th Edition now available......
  4. #4
    Join Date
    Feb 2006
    Posts
    477
    Default
    paisley( next to glasgow)
  5. #5
    Join Date
    Apr 2005
    Shropshire
    Posts
    7,671
    Default
    I used to pay £80 for a basic service until I saw an article in 'sailing today' giving detailed service instructions. From then on it was £10 for some oil. Finding and rectifying water pump problem is another matter should be done in 4hrs or so (£25/hr = £100 plus parts).
  6. #6
    Join Date
    Oct 2001
    Essex
    Posts
    2,825
    Default
    Quote Originally Posted by ghostlymoron View Post
    I'd go along with that kind of ballpark, however it does become a 'how long is a piece of string' scenario.
    Hopefully, it's just a stuck/broken impeller, which is modest to fix. However, obviously there is always the possibility of blocked waterways etc etc and with labour cost in the UK, it gets expensive.
    I have to admit, on older small outboards, i'm a great advocate for learning to inspect it yourself.
  7. #7
    Join Date
    Oct 2006
    - up to my neck in it.
    Posts
    26,802
    Default
    Try back flushing it - if that produces a flow then check your impellor. If not, then you need to consider some sort of cleaning agent to disolve the salts build-up. But be careful, the more effective solvents can also disolve aluminium.
    If repairs cost £100, what's the value of the engine? In effect, your engine is currently almost worthless, if you wreck it you have lost little, if you fix it you have an engine possibly worth £100.
    You pay someone else, they may or may not fix it (yes, professionals & experts are fallible too) and you are £100 worse off - even if the engine works, you have only broken even.
    Sell it as spares on e-bay & add your £100 to the price it fetches & buy another one
    Just some options , based on £100 repair cost & engine cost - adjust yourself to suit actual values.
    Boaty junk clogging up your shed or lockers? Chuck it in Marinaskip
    Want a used bike, spares or repairs in Staffordshire? Visit http://back2bikes.org.uk/
  8. #8
    Join Date
    Jan 2006
    Derbyshire
    Posts
    686
    Default
    Is that the going rate for an outboard engineer? If it is I have been ripped off, I paid £40 +vat per hour!
  9. #9
    Join Date
    Nov 2003
    Posts
    28,182
    Default
    Sorry,can't help you, my recommendation is Essex only...
  10. #10
    Join Date
    Jan 2005
    West of Scotland
    Posts
    2,841
    Default
    I would contact The Outboard Shop on Tarbet St in Gourock - he usually does a good job.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
