Results 1 to 7 of 7
  1. #1
    Join Date
    Jul 2007
    on the move
    Posts
    379
    Default How to attach to swinging mooring?
    Have just moved to my new swinging mooring, and it is the type with a short length of rope (about 18inches) spliced onto the buoy. It would seem to me that if you just feed a rope through the hoop, there will be a lot of chafe, so what is the correct way to connect to it?
    I have used the search facility on this site to try and find some info, but got sidetracked by some very interesting threads, so apologies if this has been covered before.
    Cheers
  2. #2
    Join Date
    Oct 2002
    Hants, UK
    Posts
    1,946
    Default
    I have a chain connected to the metal loop on the top of the bouy. The chain has a loop in the end. For pickup, there's a small bouy with a handle roped spiced to the chain loop.
    Some have the chain connected directly to the main chain to the ground tackle. It depends on teh design of the bouy.
    Some also add a plastic tube to protect the stem head fitting.
    I always wanted to learn to spell "engineer". Now I are wun.
  3. #3
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    40,653
    Default
    I'd suggest you take a look at boats on adjacent moorings to see how they are attached to the buoy and or riser chain.
  4. #4
    Join Date
    Feb 2004
    Boat (500m E of) the Clyde
    Posts
    4,374
    Default
    Sounds like the rope you refer to is much shorter than normal
    The general arrangement I have seen most often is
    (a) heavy chain for main mooring, connected to the bottom of a large mooring buoy
    (b) very thick rope attached to the top of the chain, with a large eye splice designed to be brought on board and looped over the bow cleat. This rope is typically 2 - 4 metres long, depending on freeboard height and distance to cleat. Often threaded through clear plastic pipe for protection
    (c) light rope attached to the spliced loop at one end, and a small pick-up buoy at the other end - not used for mooring, only to retrieve the heavy rope which sinks
    Hope this helps
  5. #5
    Join Date
    Jun 2003
    Orford, Suffolk, UK
    Posts
    1,474
    Default
    Quote Originally Posted by dunedin View Post
    Hope this helps
    I've tried the a+b+c system but soon omitted c [the light rope with small pick-up buoy] as being extra clutter. My b. rope must be polypropylene as it floats but nevertheless it appears to be very durable.
  6. #6
    Join Date
    Mar 2009
    Chichester, West Sussex
    Posts
    3,953
    Default
    I have similar kind of setup as wooslehunter - got some light chain attached to the mooring buoy with a small pickup buoy on the end...
    Never knowingly undersailed...
    http://hurley20sparrow.blogspot.com/
  7. #7
    Join Date
    Dec 2009
    London
    Posts
    168
    Default
    I have the (b) option. 2 x long, about 2m, of thick, floating rope. One goes thru fairlead and then around cleat, other strand thru' bow roller and then the cleat. No plastic pipe protection.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
