Results 1 to 2 of 2
  1. #1
    actionoptics's Avatar
    actionoptics is offline Registered User
    Join Date
    Mar 2004
    Posts
    383
    Default Propellor stopped singing.
    Brand new prop from Bukh would "sing" a most intrusive note between 1800 and 2200 revs.
    Today put boat on slipway and washed the hull but also followed the advice of
    a marine engineer regarding the prop.
    He told me to measure the thickness of the propellor half way around one blade
    (which turned out to be 3mm) and then on one edge only of each blade,
    file off one third of the thickness ( in my case 1mm) at an angle of 45 degrees.
    It has worked. Completely elliminated the noise.
    You know you are getting old when your back goes out more than you.http://www.actionoptics.co.uk[/url]
  2. #2
    ianat182 is offline Registered User
    Join Date
    Jul 2008
    Posts
    2,253
    Default
    Interesting, sounds similar to the vibrations on rudders where the trailing edge is squared to improve the water flow. Which edge of the prop blades did you actually reduce, the leading or trailing edge?
    ianat182
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
