Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Join Date
    Oct 2007
    Central Sweden
    Posts
    11
    Default Fuel Conditioners, Do they work??
    Hi All
    Have read a lot about diesel bug etc.... my question is do the magnetic fuel conditioners really work? the theroy is that by sending the fuel through a strong magnetic field the bacteria is broken up to single microbs?
    PS. Have sent a PM to Fuelblender without luck.
  2. #2
    Join Date
    May 2001
    UK East Coast
    Posts
    31,038
    Default
    No, they don't work. Do you also believe in Father Christmas??
    If you're worried about diesel bug, dose your tank with Startron.
  3. #3
    Join Date
    Oct 2007
    Central Sweden
    Posts
    11
    Default
    Supose he key is to have water free fuel.
  4. #4
    Join Date
    May 2001
    UK East Coast
    Posts
    31,038
    Default
    Quote Originally Posted by mike6010 View Post
    That helps, but your tank has to have a breather, and condensation inside the tank will inevitably produce water.
  5. #5
    Join Date
    Oct 2007
    Central Sweden
    Posts
    11
    Default
    Thinking along the lines of a circulation system,ie; fuelpump with coalescer element. Something that is independent from the motor. Could be set up on seperate battery and timmer.
  6. #6
    Join Date
    Jun 2009
    South Coast UK - Med next spring
    Posts
    254
    Default
    Leaving the tank close to full helps reduce condensation.
    I always add some treatment when the fuel will be around a while.
  7. #7
    Join Date
    Jun 2004
    Me: Castle Douglas, SW Scotland. Boats: Kirkcudbright, Loch Ken, Port Bannatyne
    Posts
    9,906
    Default
    No. Magnets do absolutely nothing whatsoever for any type of fuel. The "theory" is plain woo-woo from snake-oil merchants.
  8. #8
    Join Date
    Jun 2001
    Haslemere/ Evia Island
    Posts
    7,134
    Default
    Apart from dosing with bug killer, you should also keep your tank clean mechanically. Over the years sludge and grunge will collect in the tank and WILL eventually lead to problems. The only solution is to clean the tank regularly once a year by vacuuming out the bottom using a small pump, taking out some 5 - 10 ltrs or so, less as the tank becomes cleaner. Collect in clear containers so that you can see how dirty it is.
    This also removes any water in the bottom which is the cause of many mild steel tank failures (they last forever if you keep the water out)
    Of course many manufacturers leave you no access to your tank what so ever and should be taken out and shot!
  9. #9
    Join Date
    Jan 2002
    Caribbean at the moment
    Posts
    23,960
    Default
    Also, shooting boat manufacturers doesn't work either, I tried it a few times...
  10. #10
    Join Date
    Nov 2008
    Posts
    5,909
    Default
    Quote Originally Posted by Chris_Robb View Post
    The best solution to the accumulation of condensation in the tank, is the old fashioned idea of the tank having a little sump to catch water and dirt.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
