Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    oldsaltoz is offline Registered User
    Join Date
    Jul 2001
    Posts
    5,530
    Default
    As others have pointed out getting the colour right can be a problem and knowing it will age and show up again is a disappointment.
    However, if when sanding the area to start with you collect the dust and mix this with the new material you will be on the way to a match and know that the older material will fade at much the same rate as the existing gel coat, it's not perfect but it helps the new gel coat colour match last a bit longer.
    Good luck.
    Growing old is unavoidable. However, growing up is still optional.
  2. #12
    Join Date
    Mar 2002
    Posts
    6,528
    Default
    Quote Originally Posted by oldsaltoz View Post
    Good luck.
    Might help, but wouldnt you need an aweful lot of dust? Also, you are not going to get a mirror like gel finish if your new gel is full of dust/grit and muck !
    Actually one idea might be to make the repair area delibertely different, by masking of an equal square/rectangle on both sides of the boat. IE, make it obvious, rather than a naff colour match...even a different colour?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
