Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Oct 2004
    Posts
    1,825
    Default Maxsea 10.1 Not Displaying AIS (!AIVDM) Data
    Hi,
    I'd call myself pretty good at setting up AIS and GPS on PCs and successfully installed my own. However I am doing an installation for a friend and havng a problem displaying AIS data on Maxsea 10.1. I'm used to installing on 10.3 and above so I through perhaps it may be a problem on 10.1. I doubt it though.
    The AIS unit is an Icom MXA-5000 receiver and Maxsea is seeing the sentances ok. Baud rates and parity and wiring etc all good. The problem is just displaying them.
    Anyone had experience with this set-up or can offer some sensible advice on what to look for?
  2. #2
    Join Date
    Mar 2005
    Posts
    170
    Red face AIS on Maxsea 10 does not work?
    Jamie,
    You are presumably playing with that widely available version of this software that dropped off the back of the boat in front? I had repeated attempts with I think 10.3.2, and like you could see the data coming in. I formed the conclusion it was either not 'licensed' to display AIS or incapable, as I too repeatedly failed to get it to work.
    Two thoughts you might like to follow up. There is NavMonPC which is a nice bit of software that can be downloaded, and is useful in itself for anchor watches etc. It has a good AIS function. It also supports 'virtual ports' so you can also send the data on to your chart plotter software, and is ace in a gale for telling you what the wind speed and direction is without going up aloft.
    I have abandoned my fully paid up Winchart, and also Maxsea, in favour of OpenCPN, which is an open source chart plotter, supports AIS, and in my view is easier to use.
    I hope this helps. Where are you now, in the UK still with Roam, or making your way eastwards?
  3. #3
    Join Date
    Oct 2004
    Posts
    1,825
    Default
    Hi John,
    I am assuming that this is a kosher copy. You wouldn't catch me playing around with pirated software.
    I have OpenCPN but this is for a friend and he is leaving shortly. I imagine he wants to stick with MS as this is what he is familiar with. I'll offer him that alternative but unless he starts paying me for the (hours of) time I spend helping install his gear, he can like MS or lump it
    Re the original question, I will suggest that he 'buys' the latest version of MS to get round this issue, but I need to know if this is indeed the problem. I've read that other people have had the same fault with different versions of MS so it may well be the license thing to which you allude.
  4. #4
    Join Date
    Mar 2005
    Posts
    170
    Default MaxSea
    MS is at version 12 when I last looked, but is quite pricey I think? So this is a very old copy.
    Unless you can find someone who has made 10.3.2 work with AIS, then I would suggest you are wasting your time. It all looks as if it's there, but isn't.
    Of course if its kosher, you could ask the authors!
  5. #5
    Join Date
    Nov 2003
    Posts
    21,419
    Default
    In addition to the excellent stuff below, I also run XPort
    www.curioustech.net/xport.html
    which is a little freeware app for porting that works for me.
    Is Maxsea sensitive to port numbering?
    Anger is a wind which blows out the lamp of the mind.
    Robert Green Ingersoll
  6. #6
    Join Date
    Apr 2002
    Posts
    599
    Default
    OpenCPN is far better anyway in my opinion. Runs with both AIS and grib files.
  7. #7
    Join Date
    Oct 2004
    Posts
    1,825
    Default
    Fullcircle - you've changed your avatar! Port numbering isn't the issue. Maxsea can see the data no probem, it's the echoing of it on the actual workspace.
  8. #8
    Join Date
    Aug 2003
    Posts
    272
    Default Version
    My possibly erroneous understanding is that Maxsea was not AIS capable until version 12.5
  9. #9
    Join Date
    Aug 2003
    Posts
    272
    Default Maybe not
    Quote Originally Posted by NOHOH View Post
    Further to my last post, you might want to have a look at this thread on another forum..
    http://www.cruisersforum.com/forums/...0-a-39131.html
    It appears they connect the AIS through the RADAR tab.
    Are you doing that already?
  10. #10
    Join Date
    Oct 2004
    Posts
    1,825
    Default
    NOHOH - it works in 10.3.5 no problem. I would be interested to know if it should work in 10.1 though.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
