for many years I have been cooking my meals by placing two unopened cans on their side in a saucepan of water and bringing it slowly to the boil in a covered steel saucepan
I then let it simmer for a short period - let it cool
I then remove the cans and once they are hand hold hot I open them
I have been censured on scuttlebutt for saying that this is what I do.
I would love to know -
hopefully from some-one who knows
how likely is it that the contents of the cans will get so hot that it starts to boil?
then explode the can in such a way that it sends shards of tin can, shattered bits of suacepan and boiling hot chicken currey acorss my cabin resulting the demise or injury of the head chef.
is this more dangerous than sailing on a calm day without a life jacket - or walking on a slippery pontoon.
being an engineer and physist I had assumed that the tin would be strong enough to cope with the expansion of the food - I had also assumed that the chicken curry would be unlikely to boil before the water
and that if the can did go it would at worst burst a seam and then fill my sealed suacepan with wet curry sauce.
depsite many hundreds of such meals I have so far failed to split any cans at all.
Am I utterly wrong
am I going to die?
Is this more dangerous than bullriding
Dylan
PS
have moved the film of the technique from the vlog section of my website to the front page
at the bottom
if its slow to load....its friday night afterall... then start the films... pause them and they will buffer.
please do not go thinking that the short two minute film is in anyway indicative of the rest of the 100 plus odd films now available there.
It is far more exciting and than anything I have ever done
....apparently
just to save you any nervousness - no-one was injured in the making of this film
Its here
www.keepturningleft.co.uk
there are three other films on the front page - about the Alde, Ore and Butley - much more representative of KTL
Results 1 to 10 of 137
Thread: boiling cans - am I going to die
09-12-10, 15:35 #1
09-12-10, 15:48 #2
No you are not. The only significant risk is that you open the tin while the contents are still under significant pressure as a result of greater thermal expansion of the contents than of the can. As long as you avoid an eye full of hot oxtail soup you'll be fine.
There is even some food sold to be heated as you described.
09-12-10, 15:48 #3
Registered User
- Join Date
- Jul 2002
- Posts
- 27,500
Provided you are heating them in a pan of boiling water I cannot see there is any problem. If you let the pan boil dry on the other hand !!!!!!!!
There are products on the market that are intended to be heated in this way
For example:
http://www.google.co.uk/images?hl=en...w=1280&bih=909
Bugger beaten by a rat's whiskerSea Wych Owners Association website.. www.seawych.org
09-12-10, 15:55 #4
09-12-10, 15:55 #5
Registered User
Location : Tottington Hall, near Bury, in the Duchy of Lancaster
- Join Date
- Dec 2009
- Posts
- 5,001
09-12-10, 15:58 #6
Sounds like you have more experience than anyone one here to say wether it is safe or not......
So far for you, yes!
Just tell all the H&S brown nosers to bugger off and find a child with a conker or soemthing
www.cobraseawolf.webs.com - Cobra and Seawolf Owners Site
09-12-10, 16:00 #7
09-12-10, 16:03 #8
Registered User
- Join Date
- Jul 2002
- Posts
- 27,500
09-12-10, 16:03 #9
Standard military procedure, although it's a bit wimpy to let them cool down before handling and eating.
Should be juggled between gloved hands while wielding can-spanner, it is also traditional to use the hot water for shaving and washing afterwards (this is made easier as compo tins don't have labels).Last edited by Vara; 09-12-10 at 16:06.
Formerly known as colmce
09-12-10, 16:06 #10
Registered User
- Join Date
- Aug 2009
- Posts
- 866
If you are boiling a closed can in water then the pressure inside it will increase so its boiling point will also increase. Assuming the liquid in the can is water based it therefore cannot boil in the can if the outside water is boiling, however if you steam the can (ie hotter than boiling water) then you should hide behind a bulkhead.
Any increase in pressure in the can should be contained by the can provided that :-
1. there is no air in the can and,
2. the liquid in the can does not have a boiling point much lower than water, ie something like alcohol.
A hot can when opened will squirt a little out so cover it with a cloth or whatever to protect yourself.
Bookmarks
