standards of both cuisine and hygiene imporve immensely when Jill is aboard.
The can boiling is usually a winter occupation. In a small boat its only possible to stand and cook when its warm enough to have the hatch open.
In the winter at night its troglodyte time. A slow cooking porcesss is a great thing whne the gas cyclinder is so cold that its hardly working at all.
Jill will only come sailing when the weather is hot enough for swimming.
of course I am sure that if I did the sort of sailing where the two bathroom boat was almost permanently plugged into the lecy on a marina pontoon then she might come sailing more often
But having seen all those blokes sailing alone in their 33 foot lozenges.... maybe that plan does not always work.
lets face it - in most cases - its the bloke who is keener on sailing than his partner.
Most cases....
before some-one jumps on me for being sexist... pointing out that your own dear Cynthia is keener than you are does not prove a sausage.
Dylan
Results 71 to 80 of 137
Thread: boiling cans - am I going to die
10-12-10, 08:43 #71
when Jill is aboard
10-12-10, 09:16 #72
10-12-10, 09:25 #73
10-12-10, 11:02 #74
OK, here goes;
An out of spec can might be over or under spec - only under spec is going to be an issue, so assuming that 1% are out of spec (a very high estimate I think) then only 1 in 200 cans represents ANY potential issue. Now, if the can is under spec we can assume a standard deviation curve which probably puts a further 40% of the under spec cans within the bounds of safe cooking so we are down to 1 in 2000 potentially failing. Remember that these are cans with a weakness that have already been pre-processed at above the temp Dylan can achieve so if they could fail they would fail then. If the factory had that many failures the cost of clean up would force them to improve their manufacturing process.
My conclusion is that the risk of failure is even lower than that of wilnning the lottery - and the risk of winning the lottery is infinitesimal.
Consequently the assesment or damage caused is pointless.
Edit; You may not consider this an "Exam Quality" answer, but I can assure you it is streets ahead of many exam answers I have marked in my time.Last edited by Searush; 10-12-10 at 11:34.
Boaty junk clogging up your shed or lockers? Chuck it in http://groups.yahoo.com/group/Marinaskip
Want a used bike, spares or repairs in Staffordshire? Visit http://back2bikes.org.uk/
10-12-10, 11:49 #75
This has no doubt already said, but I thought i'd throw it in the pot anyway:
If the can is in contact with the bottom of the pan then it can raise above the boiling point of water and theoretically cause errr a hot can.
But does it bother me? noooo. I use ladders unassisted and have turned on a light switch with slightly damp pinkies. I live on the edge!
10-12-10, 12:02 #76
Registered User
- Join Date
- Sep 2006
- Posts
- 159
10-12-10, 12:11 #77
10-12-10, 12:15 #78
not that clever
10-12-10, 12:52 #79
10-12-10, 14:11 #80
Bookmarks
