Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 97
  1. #41
    Join Date
    Nov 2008
    Posts
    1,972
    Default
    Quote Originally Posted by AntarcticPilot View Post
    that there is a limit to the size of region over which a person can be expected to have detailed and useful knowledge.
    Not disagreeing with what you say, but what sort of area would you suggest then?
  2. #42
    Join Date
    May 2007
    Posts
    2,880
    Default
    Quote Originally Posted by NormanS View Post
    Depends utterly on the density of naming and the nature of the geography. I (through 30 years experience) have a pretty good knowledge of the geography of Antarctica - an area about 58 times the size of the UK! However, this is not comparable with the UK - there are only about 16,000 named locations, and the mapping is of low resolution compared with the UK. Furthermore, my knowledge is at an "overview" level; I can't pinpoint features at the drop of a hat (but I do know which data sources are reliable!). I'd guess I retain a few thousand names; not all by any means. I am better at the geography.
    I'd guess the present Coastguard regions are at the upper end of what is feasible for a person to know well enough to be able to use local knowledge effectively. But a complex area like the West coast of Scotland is going to be much harder to know than a relatively simple area like the NE coast of England (not much to know about the Holderness Coast, for example!). And some areas are going to have to have dynamic knowledge - for example, the Humber Estuary can change radically from one tide to the next, and doubtless places like Morecambe Bay are the same.
  3. #43
    Ubergeekian's Avatar
    Ubergeekian is offline Registered User
    Location : Me: Castle Douglas, SW Scotland. Boats: Kirkcudbright, Loch Ken, Port Bannatyne
    Join Date
    Jun 2004
    Posts
    9,906
    Default
    Of course, the MCA will almost certainly NOT use Google, but will use gazetteers provided by the Ordnance Survey, which are much better than those available on the web.
    If only there was some sort of nautical equivalent of a map, eh, and a nautical equivalent of the Ordnance Survey producing them?
    The issue of place-names and local knowledge can only partially be solved using technology, and the capacity of human brains means that there is a limit to the size of region over which a person can be expected to have detailed and useful knowledge.
    The UK coastline is roughly 20,000 miles long. For how many miles could one person claim to have detailed local knowledge? Even if it was a hundred - which I suspect is pushing it - that would required 200 specialists on duty at all times. Which with shift working would mean four or five specialists for each section of coast. Coo, recruitment would be fun, wouldn't it?
    Ultimately, though, this isn't about safety. It's about people wanting to keep their jobs. Which is fine, but different.
  4. #44
    Default
    Quote Originally Posted by Bosun Higgs View Post
    I remember the same sort of bleating when many of the lookout posts were closed but has there been the predicted carnage? No there hasnt.
    Managers are trained to manage. They hopefully will do it well but they may not. One thing is for sure, they are in a far better position to make these decisions than the "soldiers" on the ground.
    And like it or not, if there is no money to pay for the present set up it has to change.
    +1
    We dont have the money to pay for it, its that simple, we cant carry on borrowing from our children and grandchildren its crazy. Sure it would be great to say, here you go MCA times are good, lets double the budget, but in the real world things are very different.
  5. #45
    Join Date
    Jul 2001
    Posts
    16,801
    Default
    Quote Originally Posted by Ubergeekian View Post
    You don't have a crystal ball. Time will tell.
    - W
  6. #46
    Join Date
    May 2007
    Posts
    2,880
    Default
    As you will see from my post, I actually do mention other agencies. However, naming in coastal waters is not the UKHO's province; it belongs to the OS for all features above water. Below water is the UKHO, but there are serious technical difficulties in merging the databases. The information exists, but different standards are applied.
    There are also issues about unofficial names - for example, I doubt you'll find "Tinker's Hole" and "Bull Hole" on any official gazetteer.
    Actually, any coastline is infinitely long. However, it isn't the length of the coast that is the issue, it is the area density of features of relevance to the task in hand. This, of course, varies wildly from place to place. My guess (see above) is that an area the size of a normal cruising area - for example, on the West Coast, the area from the Firth of Clyde to Ardnamurchan would be reasonable for a person to have detailed knowledge. Most of us on this forum have detailed knowledge of areas about that size; a professional ought to be able to duplicate this easily; I'd guess that we (as part-timers) do less well than a professional should, so my guess is that the current CG areas are about at the upper limit of "local knowledge".
  7. #47
    Join Date
    Jun 2004
    Posts
    9,906
    Default
    UKHO may not assign the names, but they record them. The main problem on the West of Scotland is that many/most places don't actually have names, they have descriptions. Stuff the lyrical soul of the Gael - anything beyond "dark rock" and "big island" seems to have been beyond them. Or maybe they were just taking the mickey out of English-speaking cartographers and hydrographers.
    We've been through this before. You're wrong, I'm afraid, because fractal boundaries only have infinite length of you can zoom in indefinitely, and you can't do that for physical systems. Once you get to electron-scale, further zooming won't give any more useful detail - it's not like the Mandelbrot and Julia sets. So while the length of the coast line at sub atomic scales is enormous, it ain't infinite. That quibble aside. you know what I mean.
    That's a couple of thousand miles of coast (on a yachting scale...). Mull alone has three hundred miles. I think most of us up here - and that includes people with vastly more experience than mine - still find charts useful, if only to separate the hundreds of Sgeir Dubhs ...
  8. #48
    Mavanier's Avatar
    Mavanier is offline Registered User
    Join Date
    May 2005
    Posts
    1,557
    Default
    The real crux of this debate is this question:
    At what level in the system should local knowledge be available?
    Under the current system, the CG work a fairly large but hopefully manageable patch. Nobody is suggesting that the CG staff have a perfect and comprehensive knowledge of every inch of shoreline. But they should have a good, useful, working knowledge.
    Every two years they are tested on their knowledge of this area. They get to know the danger spots, the habits of boats which frequent the area, and the peculiarities of local conditions. They will know about confusing, informal, of duplicated place names- and they will know to seek clarification if needed at the point of receiving a mayday. They will not end that call until they know where the casualty is.
    The 'guys on the ground', e.g. RNLI, probably have an even better level of local knowledge, because they work a smaller patch. Once the correct rescue team has been tasked, this is vital in completing the job.
    Nobody, not even the MCA guys pushing for this change, is suggesting that local knowledge is not important. But what they are trying to do is to rely upon the knowledge of the rescue teams themselves. The assumption is that the CG who receives the mayday, and who coordinates the rescue, can 'tap into' the knowledge of the rescue teams.
    Picture this scenario:
    "Hi, is that the RNLI? Can you go and look for a boat off dubh sgier?"
    "Which one?"
    "Ah, I'll call him back..."
    Does anybody really believe that this is sensible? Does anybody really believe that this is safe?
  9. #49
    Join Date
    Jun 2004
    Posts
    9,906
    Default
    Quote Originally Posted by Robwhelton View Post
    "Which one?"
    Isn't that more or less how it works at the moment? How many sgiers dubh do the lads and lasses at Stornoway and Glasgow have to know about already?
    I already assume that if I get into trouble anywhere on the west coast, I had better be able to give my position very accurately.
  10. #50
    Mavanier's Avatar
    Join Date
    May 2005
    Posts
    1,557
    Default
    My only reference for this is a personal conversation with a CG watch leader. For those who have any faith in our CG at all that is probably good enough, for the rest of you who have already made up your minds it is obviously biased and not to be trusted.
    What he said is, short of the call being lost part way through, the CG would not end a mayday call without having pinpointed the location of the casualty. This is their standard operating procedure. The new system is going to work on the assumption that they don't have to do that.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
