Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2007
    the frozen north
    Posts
    258
    Default Vetus bow thruster controls
    I have inherited a vetus bow thruster installation on my boat (Dockrell 37). This has a remote radio control for the thruster which also operates the windless. The windless has a switch override in the forward cabin. The thruster has no override and no other control.
    As this is an obsolete product and I live in terror of the control unit being deep sixed I wanted to fit a simple switch override to somewhere near the helm - whouldn't have to be waterproof - it could go in the companionway somewhere. As I was doing other work in the bilge anyway I took the opportunity to lay in cables from thruster to companionway.
    The problem is that looking at the thruster control wiring (not the main power wiring) there are FOUR cables entering the unit (red, black, white and blue) - and going currently (boom boom) to the remote radio unit. I can't figure out why and do not know how to wire this to a switch. I am supposing that the neutral return may simply be to power up the control unit or control panel? Therefore to get a rocker switch to work all I would need to do would be to have the power to centre with the other wires as the return?
    Anyone else come across this situation?
    (I have trolled through the Vetus literature and elsewhere to no avail)
    All men dream, but not equally.
    Those who dream by night, in the dusty recesses of their minds,
    wake in the day to find that it was vanity.
    But the dreamers of the day are dangerous men,
    for they may act their dreams with open eyes, to make it possible.
    - T.E. Lawrence -
  2. #2
    Join Date
    May 2001
    UK East Coast
    Posts
    32,232
    Default
    Suggest you email Vetus, quoting the model number of your thruster.
  3. #3
    Join Date
    Aug 2002
    Posts
    2,901
    Default
    I suspect the four wire are as follows . Two from remote on/off to the dedicated thruster battery the other two port/ stbd control . 'fraid can't help on colours tho' .
    Now Promoted to Captain Clyst. My thanks are extended to Lazy Kipper .
  4. #4
    Join Date
    Apr 2007
    the frozen north
    Posts
    258
    Default
    Quote Originally Posted by clyst View Post
    The wires actually come from the thruster power unit to the radio control box - I suspect they could also go to a switch if that was installed. The red/black I assume come from the power side of the thruster and are simply there to provide power for the radio or lights in the switch or control unit???
    To use a simple switch I was hoping just to use the power through a rocker switch to the other control wires - sound sensible???
    I'm just a bit reluctant to go switching or running wires with the benefit of someone elses experiences.
    - T.E. Lawrence -
  5. #5
    Join Date
    Aug 2002
    East Coast
    Posts
    10,001
    Default
    White (1) & Blue (4) are power signal from switch. If reversed onto thruster connection block, thruster direction is reversed. I presume red (+) & black (-) Provide power to switch and a return for switch illumnation.
  6. #6
    Join Date
    Oct 2012
    Posts
    1
    Default
    I realize this is a stale post, but just having experienced a similar problem with the control module of my Vetus Bow Thruster, I did some troubleshooting.
    Ultimately the control model connects the red wire (+) to either the blue or white wires to spin the motor. You can do this with the control module attached by means of the #2 molex-style connector (assuming that connector #1 is still connected to your control module).
    If you want to see if your control module is faulty, grab a jumper wire and test.
    In my case, it turned out to be some internal corrosion inside the on/off switch.
    -Brian
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
