Results 1 to 5 of 5
  1. #1
    Join Date
    Feb 2010
    Posts
    136
    Default question about volvo d4
    just doing a bit of maintainance today noticed half inch pipe with plastic bung
    in end , under engine at front whats it for.it does not say in manuel could it be a drain for oil . engines d4 260 i b shaft drive.
  2. #2
    Join Date
    Jun 2001
    Posts
    1,791
    Default
    No, the oil drain is the one at the stbd rear near the air filter, I believe the one under the front is the coolant drain, I have similar setup but with brass bungs.
    East Coast Marine Heating & Electronics, Webasto, Wallas & Mikuni dealer
  3. #3
    Join Date
    Oct 2007
    Posts
    2,651
    Default
    Don't know the D4, but on here you can probably find that part
    http://www.marinepartseurope.com/en/...t-7746200.aspx
    when you scroll over the engine part names, you get a preview picture
  4. #4
    Join Date
    Apr 2007
    Posts
    4,079
    Default
    Presume you mean halfn inch outside diameter hose? yes its the coolant drain from the block, though to do a thorough job you need to drain the heat exchanger too, plstic bung behind sea water pump, usually trapped between sea water inlet hose.
    Out of interest you should change the coolant every 24 months AND use genuine Volvo as its not just antifreeze mixed with tap water its antifreeze mixed with distilled filtered water with nasties in.
    Do this it will make your alloy components last a lot longer.
  5. #5
    Join Date
    Feb 2010
    Posts
    136
    Default
    thanks volvo paul got all volvo parts and coolant will be doing at weekend.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
