Results 1 to 9 of 9
  1. #1
    Join Date
    Jun 2005
    Belgium
    Posts
    135
    Default Jabsco toilet leak between bowl and base
    There is a leak between the bowl and the base of the toilet. Can i repare this with silicone or a similar product? The gasket looks ok but seems to thin to effectively close the gap.
    Is this gasket present in the repair kit? As far as i can see on the photo from the repair kit it is not there. Anyway its rather expensive to buy the repair kit for the pump and the rest to replace only this seal.
  2. #2
    Join Date
    May 2001
    UK East Coast
    Posts
    32,109
    Default
    If the gasket looks OK, you could try reassembling with some sealant each side of the gasket. Are you quite sure there isn't a crack in the plastic anywhere near?
  3. #3
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    41,261
    Default
    The seal is included in the "Bowl mounting kit", "Kit E", which also includes new bolts, washers and dome nuts
    the kit is £8.45 from from Jabsco shop http://www.jabscoshop.com/marine/mar...anual-toilets/
    Select your toilet and scroll down to see the parts diagram ( click to zoom) and the parts lists
    It is not in any of the other kits. A, B, C or D.
    I'd not consider that a mint of money to fix the problem properly but no doubt it could be all sealed up with silicone
  4. #4
    Join Date
    Mar 2010
    Sunny Northumberland
    Posts
    928
    Default
    Here's a cheap replacement kit an it is portable too
  5. #5
    Join Date
    Feb 2010
    Baleares
    Posts
    2,160
    Default
    I had that too. Base is plastic and was cracked.
    Unless you want the deep aroma generated by this problem, buy a new base and install. Dead easy ... 15 minutes.
  6. #6
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    20,236
    Default
    Quote Originally Posted by Monique View Post
    You must have considerably more space around your toilet than I do. That job would be at least a morning's work for me by the time all the leaks caused by moving everything had been fixed.
    Answers to some technical queries at new website http://coxeng.co.uk
  7. #7
    Join Date
    Jul 2002
    Posts
    41,261
    Default
    About £28 from Jabsco shop. You'll also need the base valve gasket £5.50 as well as Kit E
    I'd suggest get the Kit E then if the base is OK you have what you need to fix.
    If you find the base is cracked get the new base and the valve gasket.
  8. #8
    Join Date
    Jun 2005
    Belgium
    Posts
    135
    Default
    The base looks fine, i ordered the E kit already.
    Thanks for the help everyone
  9. #9
    Join Date
    Mar 2005
    Drumadoon
    Posts
    700
    Default Waste of money
    buy a Lavac
    I fitted a replacement Jabsco 6 seasons ago, since then every part of it broke, some parts broke twice
    I spent a fortune on 'service kits' and days of my time fixing it. What a piece of badly designed, over complicated, badly made from bad materials piece of rubbish.
    Every cruise spoilt by bog trouble.
    So last summer I got a LAVAC. - bliss
    Ad littora tendit
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
