Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    sailorman's Avatar
    sailorman is offline Registered User
    Join Date
    May 2003
    Posts
    44,885
    Default
    If the wind is in the right direction the sun will be in your eyes G.Collins 1904-
    1983
  2. #12
    pvb's Avatar
    pvb is offline Registered User
    Join Date
    May 2001
    Posts
    15,613
    Default
    Quote Originally Posted by divonic View Post
    No raw water filter (that's a different issue, but the Saildrive has a grating and it's quite deep).
    I think if you were to fit a raw water filter above the pump, your problem would disappear.
  3. #13
    Join Date
    Nov 2007
    Posts
    15,336
    Default
    Quote Originally Posted by pvb View Post
    Whilst a good idea to fit the strainer, not sure it will cure the current problem. As several others have noted, it is almost certainly a worn pump or incorrect impeller. If it won't prime as it is, no hope of it lifting water even higher above the waterline. Only benefit would be that is is easier to prime by pouring water in the strainer with the seacock closed - but that does not solve the basic problem.
  4. #14
    Join Date
    Dec 2004
    Posts
    138
    Default
    I have just had the same problem on a johnson 35 Pump, it was just eating impellers and not priming. It turned out to be the seals not seating on the shaft and letting air past, when pumping water the pressure pushed the seal against the shaft so no leaks not a dribble to give them away. New seals and it sucks water straight away.
  5. #15
    pvb's Avatar
    Join Date
    May 2001
    Posts
    15,613
    Default
    Quote Originally Posted by Tranona View Post
    If it works once it's primed, a raw water filter will ensure there's water above it in the inlet pipe to prime it.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
