Results 1 to 6 of 6
  1. #1
    Join Date
    Nov 2002
    Hampshire
    Posts
    962
    Default What does expanding foam do to polystyrene?
    Need to enhance the insulation around the fridge, cannot get to and remove existing polystyrene sheets. So, after drilling suitable air vent holes, what would be the effect of introducing aerosol expanding foam?.
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    40,636
    Default
    Theres no solvent in it AFAIK that will affect expanded polystyrene.
    Worth trying it on a piece of scrap.
    Can't use the polystyrene beads I suppose
  3. #3
    Join Date
    Jul 2006
    Posts
    4,093
    Default
    Quote Originally Posted by maxi View Post
    I used expanding closed-cell foam once to stiffen a very lightly built sailing dinghy, and put in more buoyancy than the small blocks of polystyrene that were fitted by the builder.
    A test prior to filling the dinghy showed that the expanding foam sort of melted the edge of polystyrene blocks slightly, but that it all then set hard again quickly. So I left in the polystyrene, and actually added some more large chunks of polystyrene to save on the quantity of expanding foam needed. This was with a two-part liquid closed-cell foam, not Polycell aerosol stuff.
  4. #4
    Join Date
    Nov 2009
    Southampton
    Posts
    33,376
    Default
    I insulated the metal roof of my workshop using polystyrene sheets, and then used the aerosol stuff to fill in the gaps. Several years on, there's no sign of it eating the polystyrene.
  5. #5
    Join Date
    Nov 2002
    Hampshire
    Posts
    962
    Default
    Thanks Gents, just what I hoped to hear.
  6. #6
    Join Date
    Mar 2006
    Home near Stansted Airport Boat at Burnham yacht harbour
    Posts
    772
    Default expanding foam
    Cannot answer the question but just a word of caution. I once filled a punctured football to make a dan bouy. The stuff expanded mosr, much more, than I had anticipated. I had to cut off masses of surplus! Also releasing the trigger did not stop the flow!! You could end up with a frightfull mess!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
