Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Join Date
    Jan 2009
    Posts
    1,025
    Default identifying Volvo engines
    A friend recently bought a rib made about 1984 fitted with a six cylinder Volvo turbo engine. I have been trying to figure out which one but can't find any plates on it. Any suggestions where to look or what it is?
    Attached Images Attached Images
  2. #2
    Join Date
    Mar 2009
    Posts
    3,414
    Default
    Quote Originally Posted by gordmac View Post
    where are you Volvopaul?
  3. #3
    Join Date
    Jul 2009
    Posts
    750
    Default
    Looks like a TAMD 60,
    Engine number will be either on the block infront of oil filters or on block above fuel pump.
  4. #4
    Divemaster1's Avatar
    Divemaster1 is offline Registered User
    Join Date
    Jan 2002
    Posts
    3,434
    Default
    TAMD 60 ... A, B or C....
    Look here.... http://www.volvopenta.com/VOLVOPENTA...N_ENGINES.ASPX
    Regards, Alf
    I've stopped drinking water .... I have seen what it does to the bottom of our boat!
    "The only time you have too much fuel is when you're on fire."
  5. #5
    Join Date
    Apr 2007
    Posts
    4,083
    Default
    Yes id agree, and they dont look in bad nic either.
  6. #6
    Join Date
    Jul 2009
    Posts
    750
    Default
    an unusual engine for a rib, tell us more about the rib, is it jet drive?
  7. #7
    Join Date
    Jan 2009
    Posts
    1,025
    Default
    Thanks, next time I see it I will have an idea where to look.
    It is about 8m aluminium, ex rig rescue boat. It does have a jet drive. Seems to sit about 20kn (no instrumentation yet) in pretty well anything, not terribly uncomfortable either. Impressive boat.
  8. #8
    Join Date
    Nov 2001
    Posts
    1,225
    Default
    Not sure about the alternator alignment though [pic 2]
  9. #9
    Join Date
    Jan 2002
    Posts
    3,434
    Default
    Quote Originally Posted by capsco View Post
    Standard TAMD 60 I believe....
    Regards, Alf
  10. #10
    Join Date
    Jun 2004
    Posts
    1,706
    Default
    If its in a rib its probably an outdrive so a 40 series?
    41 or 42 ?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
