No disagreement at all as I'm used to masthead rigs! Also my experience is mostly from an era where there were big headsails. Our last boat had around 300sqft of main and 685sqft of genoa so we would roll a bit of that away first then put the first reef in the main at around 14/15kts apparent, we could carry more but go slower if we did. However if we were trying really hard on a gusty day and the windward leg was not too long I might get out of the cockpit and put the flattener reef in and cunningham on, then drop the traveller a tad more. SWMBO mind you was wise to these moves and since we sailed as an unmatched pair I would obey and put the first reef in only to prove most times that she was right and we went faster not slower!
Results 491 to 500 of 566
Thread: Helicopter Rescue off Dover
10-01-12, 19:53 #491
Sermons from my pulpit are with tongue firmly in cheek and without any warranty!
10-01-12, 22:13 #492
Registered User
- Join Date
- May 2001
- Posts
- 14,454
10-01-12, 22:47 #493
Registered User
- Join Date
- Jul 2008
- Posts
- 2,131
10-01-12, 22:50 #494
10-01-12, 23:18 #495
10-01-12, 23:33 #496
Registered User
- Join Date
- Apr 2009
- Posts
- 1,342
11-01-12, 00:31 #497
I suspect the same would be true of almost any 40 footer running downwind in those conditions. Granted a big cockpit gives you more room to be thrown around but you can mitigate that a bit by keeping just a helmsman and another in the cockpit, and having both of them hooked on with short tethers.
Next time, it'll all be different.
11-01-12, 00:36 #498
Registered User
- Join Date
- Dec 2009
- Posts
- 268
Your depowering technique is of course spot on but if I am correct you sail an Arcona 340 with a non-overlapping headsail. Nothing wrong with that - very seaman like for cruising and I frequently do the same - but your boat was designed for a 41 Sq m No 1 overlapping genoa not a 29 Sq m No 3. With the big genoa up at the top end of a force 3 with 7 knots added boat speed you would have 18 knots over the deck. I strongly suspect that without six heavy blokes on the rail you would be thinking about a reef. In effect you permanently have a first reef in when sailing with the non-overlapper.
The First 40.7 is similarly designed for a large overlapping genoa and I would not be at all surprised if they needed reefing in a Force 3 without a big crew. That does not mean they are not stable with a suitably reduced sail plan.
I found these 2 videos where they seem to be coping quite well in winds well over 30 Knots.
11-01-12, 00:47 #499
11-01-12, 06:59 #500
Registered User
- Join Date
- Jun 2006
- Posts
- 1,475
Too right.
Wind Type___________________Wind pressure in lbs sq ft on:
___________________Round surface__________ Flat Surface
Gale___________________ 2.8___________________ 4.0
Strong Gale_____________ 4.2___________________ 6.7
Whole Gale______________ 5.8___________________ 9.0
Bookmarks
