For cars you can get a flushing additive eg Wynns Oil Flush ,
WYNN'S ENGINE FLUSH PRODUCT DESCRIPTION
The Wynn's Engine Flush Flush is a highly concentrated detergent, designed to clean all oil lubricating systems prior to an oil change. It quickly and efficiently dissolves varnish, sludge and other contaminants from vital engine parts and prevents contamination of fresh oil by residues left behind.
FEATURES & BENEFITS OF WYNN'S ENGINE FLUSH
425ml
Cleans engines, hydraulic systems, gearboxes and differentials internally
Quickly and efficiently dissolves varnish, sludge and other contaminants from vital engine parts
Prevents contamination of fresh oil by residues left behind
Neutralizes acids
Frees sticking internal engine components by dissolving deposits
Provides extra protection during the treatment
Quietens noisy hydraulic valve lifters by removing deposits
Is compatible with all mineral, synthetic, single and multigrade oils
Recommended for all petrol & diesel engines
However, I have never used it.
Results 11 to 16 of 16
Thread: Oil change flush
11-01-12, 23:22 #11
Registered User
- Join Date
- Jun 2011
- Posts
- 48
12-01-12, 02:48 #12
I have known some use this stuff with seriously **** results & at least one new engine.
12-01-12, 08:42 #13
Registered User
- Join Date
- Feb 2008
- Posts
- 1,699
Lube oils have moved on light years and have super super sexy additive packs.
There is NO requirement for flushing oils, as modern lubes do a fantastic job at holding dangerous contaminants in suspension, particulary at Mickey Mouse marine lube oil drains. Additive pack barely breaks out into a sweat before being dumped.
Remember the engine manufacturer knows best, RTFM. Just spend on purchasing decent branded lube which meets the correct approval.
U.S EPA branded lube additives, flushing oils as expensive fraud (mainly kero based). However the additive manufacturers make huge profits and have correspondingly large marketing budgets.
Keep life simple by doing it by the book.
12-01-12, 12:01 #14
12-01-12, 12:10 #15
Registered User
- Join Date
- Feb 2008
- Posts
- 453
If you are changing your engine oil annually, you are not likely to built up much contamination. Most leisure marine users are doing less than 100 hours between changes.
You are paying top £££ for the correct oil, why waste more money on an additive.
David
04-02-12, 08:58 #16
New User
- Join Date
- Feb 2012
- Posts
- 1
Going in for an oil change or for vehicle servicing can often mean getting upsold on other products. One of these goods, an engine flush, is offered much more frequently than a motor actually needs it. Source for this article: http://www.cardealexpert.com/news-in.../engine-flush/. Engine flush is a useful tool to help prolong the life of your car. You should have knowledge about flushing because if it happens that the technician uses too much pressure or does not use the machine correctly, there is a chance that it could cause damage to the engine which could include blowing out the seals on important engine parts.
Bookmarks
