Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Water in Bilges
  1. #11
    Join Date
    Feb 2011
    Posts
    31
    Default
    My centaur has a number of leaks i have been trying to eliminate. Yes the bilges are all linked or mine are there is a small hole in the front corner nearest the engine, poor a cup of water in if they arnt blocked it will soon disappear . I,ve found the following so far.
    Slow leak from the water pump on the engine.
    The teak foot treads by the hatch are rivited through, they are well known for leaking, it drips on the engine..
    The winches bolted through again another slow leak. Drips on the cushions.
    The hatch depends on the direction of the rain and window seals. Also i had a number of holes from poorly fitted instruments, tiller pilot etc . Good luck i still haven't found all of them..
  2. #12
    Join Date
    Jul 2001
    Australia, East coast.
    Posts
    6,005
    Default
    Quote Originally Posted by duncankellett View Post
    Hi,
    Thanks for the reply. It is definitely salt water, I have tasted it today after reading some of the replies. Only a couple of inches and I have sponged it all out and will check again tomorrow. We have recently moved it to a new mooring - wonder if it could be sitting at a slightly different angle when drying out each tide.
    Thanks again.
    Next time you wipe it out spread some talcum powder around and it will indicate the point of entry.
    Good luck and fair winds.
    Growing old is unavoidable. However, growing up is still optional.
  3. #13
    Join Date
    Jan 2011
    Hayling Island
    Posts
    705
    Default
    Had a problem on my previous Westerly boat, after having the keels reseated, which seemed to indicate that there was still a problem. Turned out that the water that was appearing in the keel fixings was in fact moving from under the cockpit sole when the boat settled at an angle. Panic Over.
  4. #14
    Join Date
    Apr 2004
    Posts
    1
    Default water in bilges
    i got a westerly pageant which iv`e noticed water on top of bilges tastes of salt but as its kept on mooring which drys i`m almost certain its from keel bolts so i`m going to lift her out and see what damage is i also know some of water comes from window but dosn`t account for both sides will keep you posted on what happens
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
