Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
  1. #11
    Join Date
    Mar 2002
    Posts
    6,476
    Default
    Not much isnt galvanised surely? The brakes-well they are totally disposable. The roller nuts and bolts.. so what... front whell.. £15? Thats about it,isnt it?
    Re JFM and galvanising.. only what I heard but it isnt so easy these days as there are now a zillion H+S rules putting the bloke and his the shed out of business?
  2. #12
    Join Date
    Mar 2004
    Posts
    804
    Default
    To some extent you're right.
    But on my last one, things like the backs of the hubs, the ends of the roller posts, the brake cables etc etc....
    I know it's not a lot to replace that kind of thing, but it's hassle - if they don't rust in the first place - well that's got to be better I'd think.
    Why can't we work 2 days a week and boat the other 5????
  3. #13
    Join Date
    Jan 2005
    Posts
    7,608
    Wink Good enough for Boeing
    "It was the crew's fault"
  4. #14
    Join Date
    Mar 2002
    Posts
    6,476
    Default
    Quote Originally Posted by ontheplane View Post
    Dont put it in water is the best tip
  5. #15
    Join Date
    Feb 2008
    Posts
    345
    Default
    Can't imagine waxoyl would harm galvanizing. I have used waxoyl on various bits of bright plated stuff like zinc plate on bolts, pipes and engine mounts for years. It's certainly had no detrimental affect. It has preserved them like new in fact.
    On the galvanized chassis I would say waxoyl applied inside the chassis members (presuming them to be hollow sections) and perhaps any rough bits at welds would be a good idea. Do they sill make the waxoyl pump/spray kits for doing inside chassis sections ?
  6. #16
    Join Date
    May 2001
    Posts
    9,596
    Default
    Read somewhere that spraying with WD40 and then rubbing with wire wool brought galvanised bits back nice and shiny. I did spray mine with duck oil just a few days ago, doesn't make it sticky but does help protect it.
  7. #17
    Join Date
    Mar 2004
    Posts
    804
    Default
    gjgm
    That is the plan actually.
    I want to set it up so I only have to get the tyres (not the rims or hubs) in the water.
    I intend to have it set up so that the trailer is a bit too long for the boat, the axles are set further forward so that when it sits on the trailer there is about 1.5m of trailer and rollers behind the boat.
    Once in place on the slip, I want to have it set up so that the rear roller is near the surface of the water, but nothing else is in - then let the boat "roll" off (controlled by winch of course).
    Hopefully this will save the brakes and hubs, which are the most expensive to replace.
  8. #18
    Join Date
    Feb 2008
    Posts
    345
    Default
    Quote Originally Posted by longjohnsilver View Post
    Galvanizing is zinc. It does weather/corrode and therfore protects the steel , like the anodes on the boat.
    Wire wool or anything abrasive may well polish the galvanizing. But it will erode the galvanized coating and reduce its life.
  9. #19
    Tremlett 15's Avatar
    Tremlett 15 is offline Registered User
    Join Date
    May 2009
    Posts
    323
    Default
    have used Galvafroid for touching up.......
    http://www.google.co.uk/url?sa=t&rct...y8EpEj11uuzwDw
  10. #20
    Join Date
    Aug 2003
    Posts
    150
    Default
    I have had several trailers from new and the only trailer I would recommend is built by RM Trailers. The bearings are sealed for life, the water flushing kit offered works well - flushes the saltwater out of the brakes, the brake cables are the open type and do not seize up. But like anything it has to well looked after - washed down immediately after every immersion.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
