Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    gps999 is offline Registered User
    Join Date
    May 2011
    Posts
    17
    Default What do u think?
    Ive removed the MD7A and saildrive from my boat. Engine room cleaned painted and refitted ready for a Beta 20 and saildrive.
    My question concerns the tank of red diesel. Now would be the perfect time to drain and clean if necessary.
    I am thinking about running the new engine only on the white stuff in anticipation of the red disappearing,(not not mention problems when across the channel) ?
    What do the informed folk on here think?
  2. #2
    sailorman's Avatar
    sailorman is offline Registered User
    Join Date
    May 2003
    Posts
    44,797
    Default
    Quote Originally Posted by gps999 View Post
    do you plan to visit Belgium then
    If the wind is in the right direction the sun will be in your eyes G.Collins 1904-
    1983
  3. #3
    Join Date
    Aug 2004
    Posts
    389
    Default
    Don't think anyone checks whether the engine has any red stain in it - only the colour of the fuel in the tank. So if you can use up the existing fuel on this side of the channel, why waste it? If you're about to head off for Belgium, then I guess it might be worth draining the tank.
    Jonathan / Aeolus
  4. #4
    Join Date
    Jul 2002
    Posts
    27,459
    Default
    If the tank can only be removed after removing the engine then now is a good time to take it out to clean and inspect ... irrespective of the colour or creed of the fuel it contains.
  5. #5
    Join Date
    Mar 2010
    Posts
    303
    Default
    I have 120 litres of it in my tank in Holland, Been there near 12 months now and no one has checked, customs been on 3 times but havent asked to look. Ive even got the receipt there waiting to shop them.
    I wonder how much deeper the ocean would be without sponges.
  6. #6
    sailorman's Avatar
    Join Date
    May 2003
    Posts
    44,797
    Default
    Quote Originally Posted by nauticalnomad View Post
    tell the whole story then
    1983
  7. #7
    Join Date
    Mar 2010
    Posts
    303
    Default
    Quote Originally Posted by sailorman View Post
    The Dutch customs seem to only care about the length of your knife blades...
    Didnt even question the full tank of fuel
  8. #8
    rob2 is offline Registered User
    Join Date
    Aug 2005
    Posts
    2,519
    Default
    Think laterally. If you're going to clean the tank, regardless of whether you then change to road derv, why not get value from your discarded fuel by offering it in appreciation of other boat owners' assistance with your refit? I'm all for trading favours to save cash, but some form of thankyou is appreciated - like when someone has done half a day's work for you, commercial value nigh on two hundred smackers (?), paying for the pub lunch just lets them how much it was appreciated and gives you an excuse for a decent meal.
    Rob.
  9. #9
    Seajet's Avatar
    Seajet is offline Registered User
    Join Date
    Sep 2010
    Posts
    12,109
    Default
    Cleaning & checking the tank is far more important than the fuel in it; if it's a valuable amount, decant it then refill afterwards, but I suggest you don't pass up a chance like this.
    I was once on a motorsailer with 2 large tanks, untouched for years; I insisted on checking & cleaning the tanks, as were obviously in for a rolly ride in this boat across Biscay.
    Both tanks had a layer of sludge a good inch deep, just waiting for a chance for a blockage .
  10. #10
    ianat182 is offline Registered User
    Join Date
    Jul 2008
    Posts
    2,252
    Default
    Unless your tank is a stainless one there's likely to be some corrosion and grunge in the bottom of it. If it is sound then perhaps a PELA pump could be used to drain it in situ and perhaps remove some of the grunge, however at the stage you've reached and have the access, I'd get the whole tank out so it can be thoroughly drained/cleaned more easily. Make sure you don't crush the vent pipe when putting it back in.
    ianat182
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
