Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Join Date
    Jul 2004
    Posts
    970
    Default
    managed to find a manual on board today, it says after changing the fuel filter you need to 'vent' the system, is this done by bleeding the injectors or is there a primer pump?
    "Boat that never leave pond, never know wonder of ocean...."
  2. #22
    Join Date
    Jul 2002
    Posts
    27,467
    Default
    Quote Originally Posted by aquaholic View Post
    The owners manual explains what to do.
    Two stages. firstly with the lift pump while venting the filter. Secondly at the injectors while spinning the engine on the starter
    The same explanation but with clearer diagrams in the workshop manual
    see the link in Playtimes post above
  3. #23
    Join Date
    Feb 2003
    Posts
    7,508
    Default
    Quote Originally Posted by VicS View Post
    In the real world Vic, just need to vent the filter, then the engine will splutter and start. Ive never needed to vent the injectors. The biggest prob is the puny lift pump, thats why I put the thumb pump filter in place of the primary CAV 296. The return fuel system allows it to self blreed. For info the Montego 2.0 diesel lift pump is the same, I bought one off ebay for £20 ish, a lot cheaper than the VP one!
    Its exactly the same as the VP one.
    Stu
  4. #24
    Join Date
    Jul 2002
    Posts
    27,467
    Default
    Quote Originally Posted by skipper_stu View Post
    Stu
    I know. My old Fiesta car did not have a lift pump ( the Pug has a rubber bulb) Just used to screw on the filter and crank the engine 'til it fired and with luck ran!
  5. #25
    CelebrityScandel is offline Registered User
    Join Date
    Apr 2007
    Posts
    339
    Default
    In the real world Vic, just need to vent the filter, then the engine will splutter and start. Ive never needed to vent the injectors. The biggest prob is the puny lift pump, thats why I put the thumb pump filter in place of the primary CAV 296...
    We had an MD22L on a previous boat some years back and it would usually prime itself with no venting and start after about 4-5 seconds of cranking followed by some coughing and spluttering even after both the primary and secondary fuel filters were changed. That with about an average, depending on fill, 1m lift from the fuel tank to the lift pump. But we did have a big water lift muffler so a bit of cranking was not an immediate backflooding issue.
    Agree on the puny lift pump if operated manually but on the very odd occasion when the engine did not self prime quickly and with other small engines not so compliant I just opened the vent on the filter and cranked the engine with the injectionpump/governer stop lever held in the stop position until fuel vented. To prevent the risk of back flooding if long cranking was required I just closed the raw water seacock and remembered (always ) to open it before actually starting the engine.
  6. #26
    nigelmercier's Avatar
    nigelmercier is offline Registered User
    Location : Kent, boat in San Miguel Marina, Tenerife, Canary Islands
    Join Date
    Jun 2007
    Posts
    6,674
    Default
    For info the Montego 2.0 diesel lift pump is the same, I bought one off ebay for £20 ish, a lot cheaper than the VP one! Its exactly the same as the VP one.
    I've just bought http://www.ebay.co.uk/itm/220883944193, only a tenner more than the Volvo Penta gasket kit that I sent back because it didn’t fit.
    Nigel
    FREE Bavaria Yacht Forum: www.bavariayacht.info
  7. #27
    Join Date
    Jan 2007
    Posts
    935
    Default
    Stu
    Can you identify which thumb pump filter you used, please. I'm considering the same mod.
    Loves sailing, hates gardening
  8. #28
    Join Date
    Feb 2003
    Posts
    7,508
    Default
    Quote Originally Posted by Playtime View Post
    I bought it from a scrappie, it was off a fork lift, but i know they fitted them on older fords. It uses the cav 296 filter.
    Stu
  9. #29
    EuanMcKenzie is offline Registered User
    Join Date
    Oct 2005
    Posts
    500
    Default
    wrong engine was thinking of MD21 A/B which has OHV
    HR Rasmus, Cabatach - Largs
    Red Optimist in the Shed!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
