Results 1 to 4 of 4
  1. #1
    Join Date
    Jun 2005
    Posts
    11,325
    Default Best clear varnish or lacquer for Cherry veneer?
    Boat is mostly in cherry either solid or veneered, with a few parts done in contrasting darker teak.
    Redoing some of the interior finish which is a light golden colour... All of the clear varnishes I find have slight pigmentation that darkens the wood. What I want is the colour of the wood when I wipe it with thinners!
    Any ideas?
    If I'd wanted to live in a Banana Republic I'd have gone to South America.
  2. #2
    Join Date
    May 2006
    Posts
    2,882
    Default
    Osmo PolyX hard wax oil, assuming you have completely removed the existing finish. Brush on, wipe off surplus after half an hour. Repeat the next day. Maybe a third coat in high wear areas. Expensive, but the best oil finish I have ever used for interior work.
  3. #3
    northwind is offline Registered User
    Join Date
    May 2010
    Posts
    455
    Default
    Quote Originally Posted by srp View Post
    +1
    I hadn't thought about using it on the boat, but I use it for furniture, you can apply it either with a cloth or brush.
  4. #4
    prv is offline Registered User
    Join Date
    Nov 2009
    Posts
    13,397
    Default
    Must say that I've not noticed Epifanes darkening things - a wipe with thinners seems to be a pretty good approximation of how it will end up looking. But perhaps you've checked more carefully than I have.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
