Results 131 to 140 of 470
23-02-12, 23:37 #131
Sermons from my pulpit are with tongue firmly in cheek and without any warranty!
23-02-12, 23:48 #132
See previous reply. I think that the topsides shape which forms the underwater shape if inverted determines the ability to self right quickly, it needs to be unbalanced enough to get the keel to an angle where it then levers things over, if that makes sense. The lead mine bit I think too is a bit misleading, because modern fins are deeper and often have bulbous bottoms so that the effective righting moment is just as great as it is on a shallower but heavier long keel.
24-02-12, 01:30 #133
What about a monohull with the horizontal foil which stops heeling?
http://www.mysailing.com.au/news/dyn...s-go-fast-gearLast edited by Sybarite; 24-02-12 at 01:32.
24-02-12, 07:42 #134
My first thought was "that looks like a weapon!"... then reading the article the guy says "cool and menacing."
Its weakness is that its a mechanical system, so it could fail the robustness test. If the foil jams for any reason or gets bent by striking a submerged object offshore, you're condemned to a single tack until you eventually hit land. If the yacht is conceived for speed and built around this concept, then it isn't going to have a lot of stability without it. Heaving-to? Running before a big sea?There are always two ends to a pudding
24-02-12, 10:05 #135
Registered User
- Join Date
- Oct 2002
- Posts
- 3,826
24-02-12, 10:16 #136
24-02-12, 10:25 #137
Registered User
- Join Date
- Mar 2010
- Posts
- 40
I would have misgivings about horizontal foils for crossing oceans. A boat's tendency to heel is nature's way of relieving stress. If a yacht is too stable the loads will get too high and things will start to break.
It is good to have a boat that gives you warning when things are getting too much and the systems or rig should ensure that it is easy to reduce sail.
24-02-12, 10:36 #138
That is of course assuming that the boat wasn't designed with that level of stability in mind and fitted with apropriate equipment. Which of course it would be.
It's an interesting concept, but not one that I would expect to become mainstream on cruising boats though. I think the appearance of "Open" type boats on the cruising scene is far more interesting.You never know, I might be right!
24-02-12, 10:43 #139
That rather depends on how you understood it, I thought I knew what I meant to say.
What I meant is that a deep narrow wineglass shaped hull with a long (but shallower) heavy keel is no less likely to be rolled over than a flatter hull shape with a deeper narrower keel that maybe weighs a bit less. Boats in the 1979 Fastnet (in weather about as extreme as it can get around here) that rolled over were rolled over by the seastate not by the wind pressure. Subsequent tank testing at Southampton University proved that any boat regardless of design will roll if it meets the 'wrong' wave. The narrower deeper keel might well right quicker if rolled than a wide flat one (as were quite a few Fastnet boats), simply because of being less stable upside down, but wide boats with some volume in the area above deck such as with coachroofs will also be unstable enough to initiate the righting process.
All of which is relevant only to those who expect to be rolled over, but some people have this idea that long keeled boats are immune to such things which they are not.
24-02-12, 10:47 #140
Registered User
- Join Date
- Oct 2002
- Posts
- 3,826
Bookmarks
