Page 41 of 47 FirstFirst ... 3132333435363738394041424344454647 LastLast
Results 401 to 410 of 470
  1. #401
    Join Date
    Jul 2009
    Posts
    7,689
    Default
    So far, the most reliable technique I have found for dealing with bow windage is to use my 25lb lead 'drudging' weight. Just let it go over the bow when the boat is in midstream, wait a few moments while she settles head to wind and then motor slowly ahead, recovering the weight as you go.
    Whilst waiting for the boat to settle head to wind, there is time to light the pipe that John Morris probably assumes us old fuddy-duddy long-keelers smoke.
    'The lyf so short
    the arte so long to lerne.'
  2. #402
    Barnac1e is offline Registered User
    Join Date
    Jan 2008
    Posts
    1,814
    Default
    Quote Originally Posted by flaming View Post
    There is a school of thought that it's the keel that trips the boat up and rolls it, and so with a raised keel the boat will just slide sideways.
    I can vouch for that. During a race from Whitby once, going north in the bay towards Sandsend, for those that know the area, I went well inshore to get out from the strong, south-going tide, which I thought I could do with my centre-plate up in the beam wind and which the usual bunch of competitors couldn't safely do with their larger, fin-keel yachts.
    All went well despite a heavy swell that was taking the light wind out of the sails sometimes until we came to Upgang Rock, a submarine uprising over which we would have plenty of clearance. However, out of nowhere the swell broke (with no previous indication of breakers there) and the boat started surfing sideways at an alarming rate. Eventually, in shallower water the wave subsided and, with still enough water to sail off, I cleared the shore, quite shaken.
    If I had had the plate down, or a keel boat, I think I would have been rolled with the height of the wave. As it was, I obtained the title of 'Beachcomber' in the clubhouse later.
  3. #403
    Bosun Higgs's Avatar
    Bosun Higgs is offline Registered User
    Location : they think they might have seen me, but have they?
    Join Date
    Nov 2009
    Posts
    10,512
    Default
    Quote Originally Posted by parsifal View Post
    Bet you have "baggywrinkle" on your rigging and maybe thole pins and hemp rope and stockholm tar on your gansey and walk with a sailors roll as you head for the Shipwrights Arms. . Beard?
  4. #404
    Join Date
    Jul 2005
    Posts
    6,485
    Default
    So much to learn. ( tempting to make a snide comment about boat handling learning or spending ££ on paper tickets) but.
    Parsifals drudging idea I have never tried though v tempting to deploy the anchor from the cockpit if one is so set up, enough to bump vertically along the seabed and assist in backing out. I guess you would have to know that the ground is flattish and not obstructed. One more trick to try.
    MichaelChapman I raced on a smack the Ellen which had one diesel and two saildrives hydraulically driven- impressive, especially to the unsuspecting in close quarters.
    LongKeeler the idea of stowing the sweep handily along the backstay-perfect. That would be well supported to withstand the reverse steering forces. This I have to try. Ironically one assumes it is better to raise a self steering paddle for closequarters manoeuvrability but hmmm..some swing out and then align fore and aft but if the turning moment could be kept active, that might be enough in itself.
    March is perfect marina parking practise time midweek, lots of empty pontoons and no traffic or bored watching AWB observers?
    * Please add your own smiley cos the 'choices' seem a bit wubbish
  5. #405
    Join Date
    Jul 2009
    Posts
    7,689
    Default
    Quote Originally Posted by Bosun Higgs View Post
    All of that except that I wouldn't be seen dead in a beard! I cannot imagine why on earth anyone would countenance one.
    'The lyf so short
  6. #406
    Robin's Avatar
    Robin is offline Registered User
    Join Date
    May 2001
    Posts
    10,393
    Default
    Well after all the arguments about the benefits of long keels on here the pro camp have probably scuppered more long keel hopefuls by their tales of handling tricks and treats than any logical case for better performance ever could.
    Sermons from my pulpit are with tongue firmly in cheek and without any warranty!
  7. #407
    Join Date
    Jul 2009
    Posts
    7,689
    Default
    Quote Originally Posted by Blueboatman View Post
    The idea is not to help you back out, it is to hold the bow facing the wind temporarily so you can then motor out ahead.
    In practice I lead the line from the cockpit via a snatch-block to a bow fairlead, then back aft 'outside all', and prop the weight on the toerail by the cockpit where it can be easily pushed off into the water. Recovery can then be done from the cockpit and the weight lifted on board when in open water.
    There is little chance of snagging the weight on anything because it is only a 2" square section of lead window sash. That's why I use a weight and not an anchor, although an anchor could be used if the line was attached to its crown.
    As John Goode, from whom I got the idea, points out, marinas are not dredged any deeper than the minimum necessary because dredging costs money so you are not having to haul in long lines
    'The lyf so short
  8. #408
    Scotty_Tradewind's Avatar
    Scotty_Tradewind is offline Registered User
    Join Date
    Oct 2005
    Posts
    3,000
    Default
    In my Twister I tried the technique of pointing her tail into the wind and yes, into a reasonable breeze or strong wind it does work.
    My Tradewind, an even heavier displacement long keeler, seems to do the same and going astern some distance it's dead simple to steer, I simply give a blast on the bow thruster!
    You never get to where you want to go if you only travel on sunny days.
  9. #409
    Join Date
    Jul 2005
    Posts
    6,485
    Default
    Re MoboRobin of Poole(. Just wait till you get a norther blowing through some overcrowded Banamas anchorage and those tophampered mobos start dancing and dragging...
    'Welcome to my world' for grown up boat handling! Of course the 'Bale-out-to-sea' option that we long keelers love, may not look so attractive then.
    (Tongue in cheek).
    Don't know about you but I am taking on board some genuine tips that may be useful to any boat owner of whatever type, having like you owned more than one boat type.
  10. #410
    Robin's Avatar
    Join Date
    May 2001
    Posts
    10,393
    Default
    (Tongue in cheek).
    I don't want to kick off a new anchor thread but we are planning on a) upping our 66lb Claw to a 88lb Delta b) picking less crowded anchorages where possible (I heard the septics anchor like the French) c) Getting out of dodge quick if needed since we can wind up to 17kts if needed!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
