Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: USB GPS
  1. #11
    Join Date
    Nov 2009
    Posts
    884
    Default
    Quote Originally Posted by CAPTAIN FANTASTIC View Post
    What type of charts do you have?. Where are you getting the GPS with chartplotter from? Let us know how you are getting on with the setting up; I am also planning to buy same equipment.
    You can get it direct from Belfield as a package.
    http://chartsandtides.co.uk
    The charts are the UKHO ARCS charts - all 800 of them on disc or memory stick, and being raster charts, means they are exact scans of the Admiralty paper charts.
    Naturally the program automatically selects the correct chart as you zoom in or out.
    http://www.ukho.gov.uk
  2. #12
    MoodySabre's Avatar
    MoodySabre is offline Registered User
    Join Date
    Oct 2006
    Posts
    10,552
    Default
    There's a test of the Belfield plotter and others too in Sailing Today current issue.
    My son is selling his Achilles 24 in West Wales
  3. #13
    Join Date
    Jan 2012
    Posts
    109
    Default
    I went the open cpn and cm93 charts, since im a cheapskate, depending on your morals there are garmin atlantic ones kicking about as well, the first usb dongle i got crashed windows, the second one is better but sometimes not recognised by windows, getting a reliable gps usb dongle was the difficult part for me!
  4. #14
    NickRobinson is offline Registered User
    Join Date
    Dec 2007
    Posts
    717
    Default Blue tooth?
    Has any one tried a BT GPS?
    My set up uses a BT USB dongle to talk to the GPS total cost less than £10. for both bits.
    The GPS is rechargeable so it can be used remotely (eg higher up inside the cabin) but not really necessary. It runs for 12/24 hrs if not on charge.
    http://www.ebay.co.uk/itm/NEW-GLOBAL...ht_3714wt_1059
    (no connection, other ads available!)
    Nick (Rivendell
  5. #15
    Join Date
    Jan 2007
    Posts
    935
    Default
    Quote Originally Posted by NickRobinson View Post
    Yes - I use a GlobalSat BT 338 as a back-up and with my Dell PDA which runs MemoryMap with Maptech charts, in the cockpit for pilotage. BT works well, without the set-up problems that I have encountered (as have others here) with USB GPS.
    The laptop runs down below taking it's primary feed from the fixed GPS (Garmin 128) and a NASA AIS engine. The laptop runs OpenCPN with CM93 and Maptech (Admiralty raster) charts. I use Maptech for route planning and real time nav and the vector charts (with detail turned down) for AIS display, which is particularly good on OpenCPN.
    I'm also now using NavMonPC for instrument display, logging and multiplexing/virtual COM port provision, although the virtual ports are not really needed now as I no longer run Maptech, just OpenCPN.
    Loves sailing, hates gardening
  6. #16
    V1701's Avatar
    V1701 is offline Registered User
    Join Date
    Oct 2009
    Posts
    2,460
    Default
    Bluenext dongle here, works fine (once configured with the help of the forum ) with Samsung netbook, Open CPN/CM93. A great backup to the chartplotter...
  7. #17
    Join Date
    Jul 2004
    Posts
    580
    Default
    I have recently discovered 'Extgps'
    http://www.symbian-freeware.com/download-extgps.html
    which allows your Symbian based gps , Bluetooth phone to send gps to your laptop
    I have a Nokia E71 which works fine with this.
    I paid , I think , about £4 for mine using the Nokia Apps store but I note you seem to get it free on the site I have posted here.
  8. #18
    Join Date
    Nov 2009
    Posts
    884
    Default
    Quote Originally Posted by Playtime View Post
    Navmon is good for its nmea handling but the instrument displays are less impressive, not customiseable nor resizeable, not that this is a complaint since its a free download!
    You might like Polarnavy's Polarview instruments. You can customise them fully and also re size the window, and have it ontop of Belfield.
    You can choose an anlogue or digital display for most parameters.
    I
  9. #19
    Join Date
    Sep 2011
    Posts
    21
    Default Opencpn
    Opencpn looks very attractive. Does any one know if it is updated and how frequently.
  10. #20
    Join Date
    Sep 2001
    Posts
    6,990
    Default
    Quote Originally Posted by sutton sailor View Post
    Do the sums:
    Code:
    Name	Modified
    2.5.0	2011-07-26
    2.3.1	2010-12-31
    2.3.0	2010-12-18
    2.1.0	2010-06-26
    1.3.6	2010-01-07
    1.3.4	2009-10-01
    1.3.2	2009-07-11
    1.3.0	2009-05-09
    1.2.8	2008-12-25
    1.2.6	2008-08-31
    1.2.4	2008-04-20
    1.2.2	2008-01-02
    1.2.0	2007-04-20
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
