I'm looking to install a tank for meths storage for the coming season on board. I am not too keen on the fluid being in plastic bottles about the cabin in case of leakage.
The 1l metal camping fuel bottles would suffice. However I have in mind a 5l or so tank, permanently fitted to bulkhead with a small tap for filling up the cooker's cartridges would be a neater solution.
Does anyone know where one would look for such a thing?
Results 1 to 10 of 14
Thread: Meths Storage
23-02-12, 22:10 #1
Registered User
- Join Date
- Mar 2007
- Posts
- 222
Meths Storage
23-02-12, 22:30 #2
How about 2litre stainless steel thermos flasks for around a tenner each? Loads on e-bay.
http://www.ebay.co.uk/sch/items/__st...=284591_284611
23-02-12, 22:32 #3
How about a fuel tank from a Taylor's cooker, they appear on eBay on a regular basis
23-02-12, 22:37 #4
Registered User
- Join Date
- Mar 2007
- Posts
- 222
That Taylor's tank is the idea I was looking for. At £90 for a second hand and dented tank, I may stick to the flask idea though.... will keep an eye out.
Unless there are other options available akin to the taylors tank but better value?
23-02-12, 22:41 #5
If you buy your meths from a decorators merchants (Brewers, Cane Adam, etc) it comes in a 2.5L metal can.
Hic dracones.
23-02-12, 23:17 #6
Registered User
- Join Date
- Aug 2005
- Posts
- 2,525
If you use the camping containers you could put them in a bicycle drinks cage, screwed to the bulkhead. Drinking containers are varnished on the inside to avoid tainting the drink, so probably best to use one intended for fuel - same aluminium bottle but not varnished.
Rob.
24-02-12, 07:40 #7
If I'd wanted to live in a Banana Republic I'd have gone to South America.
24-02-12, 08:30 #8
I have a scrap internal fuel tank off an outboard that could do the job, it's not a regular shape or pretty but it does have a tap on the bottom.
I use a Fairy liquid bottle, it pours at just about the right rate for the fuel to soak into the wadding, squeeze a bit to speed it up. I keep the bulk in a gallon tin, like an old oil can, but I don't know if it's worth it the 5L plastic ones never failed on me.Bob.
Any bull in this post may be composted.
24-02-12, 09:43 #9
Registered User
- Join Date
- May 2001
- Posts
- 14,476
24-02-12, 09:58 #10
There are lots of tanks about the right size designed to be bolted to something - Seagull o/b, Atco mower, etc.
Probably easier to get down to the local scrappy and get a suitable header tank from a car.Left hand down a bit.
Bookmarks
