Does anyone have experience of connecting an external antenna to an Icom handheld VHF (IC-M31)?
I have a couple and thought that I could set one up in the office to monitor broadcasts but given its location I would need to connect it to an external antenna. I cannot identify the connector type on the rubber duck so am scratching my head quite how to do this.
Any ideas?
Cheers,
Andy
Results 1 to 9 of 9
18-03-12, 16:26 #1
Connecting an external antenna to an Icom handheld
Fifteen men on a dead man's chest
Yo ho ho and a bottle of rum
18-03-12, 16:37 #2
18-03-12, 16:38 #3
Registered User
- Join Date
- Jul 2004
- Posts
- 160
Look at this page
http://www.jgtech.com/shop3page2.htm
About half way down, in the ICOM Handhelds section, you will see an adapter for what you want.
(I am sure other suppliers are available
18-03-12, 19:05 #4
18-03-12, 19:13 #5
Handheld aerial connectors are usually either SMA (50 ohm) or a special proprietary connector. I believe Icom is SMA. You need to look under 'specification' in the manual and it should tell you.
John
www.saltyjohn.co.uk
18-03-12, 22:19 #6
I purchased the adaptor bit when I purchased the radio from a 'radio' shop. I suspect that maplins or others do a connector and the easiest way is to take the radio and aerial in to the shop and ask.
My brothers shop http://www.tomfoxtailoring.co.uk/
19-03-12, 09:55 #7
Thanks Boathook, I think that you may be right. Sometimes simply going over to the shop is quicker than scratching your head and looking at the web.
Cheers,
AndyFifteen men on a dead man's chest
19-03-12, 10:43 #8
It is a generic connector about £3.oo in Maplins and easy enough to find on the connector stand if the same as other Icams and Yaesu
http://www.ebay.co.uk/sch/i.html?_fr...All-CategoriesLast edited by Bilgediver; 19-03-12 at 10:56.
Eastern Scotland and beyond.
19-03-12, 13:31 #9
I bought an adapter recently and no problems testing it on my Cobra hand held.
Maplin are probably the best bet unless you are buying a few other connectors as well. I bought several connectors from "26hb896" (Rocket Radio Letchworth) on eBay as they happened to have all the different connectors I needed. Never used them before but feedback was 100%, prices were OK and delivery was quick.
It was listed under:
PL259 PLUG (SO239 SOCKET) to SMA MALE PLUG ADAPTOR
Sod's law, they are'nt advertising that connector just now, but plenty of others are if local Maplin don't have any either.
Bookmarks
