Results 1 to 8 of 8
  1. #1
    lenseman's Avatar
    lenseman is offline Registered User
    Join Date
    Jun 2006
    Posts
    6,700
    Arrow Mad Skills - Volvo Ocean Race 2011-12
    When your yacht starts to fall apart below the water line whilst transiting the Southern Ocean, you just have to go over the side and start to drill holes (x 13) through the hull to hold it together:
    http://www.youtube.com/watch?feature...&v=HxgXE6k99EY
    regards David - DSW Marine Engineering
    www.dswmarineengineering.com
  2. #2
    Erik C's Avatar
    Erik C is offline Registered User
    Location : In the mountains 80 km outside Rio de Janeiro
    Join Date
    Nov 2010
    Posts
    2,871
    Default
    Strange they did not use any sort of backing plate, those nuts look very small.
  3. #3
    Join Date
    Feb 2011
    Posts
    660
    Default
    I have to agree with the other video comments. VOR has gone far to high-tech. The designers seem to have been inspired by a tuna sandwich for construction ideas.
  4. #4
    lenseman's Avatar
    Join Date
    Jun 2006
    Posts
    6,700
    Default
    Quote Originally Posted by WouldbeSailor View Post
    When you are in the southern ocean, you just can't pop out to the local chandlery to buy backing plates. They did cut strips of something, using an angle grinder/cutter on deck, to fabricate some form of 'plate' and the shoring poles were set to hold them in place.
    Also, the movement in the two skins of the hull was up and down so the shear strength of the thirteen bolts was the most important factor.
  5. #5
    Twister_Ken's Avatar
    Twister_Ken is online now Registered User
    Join Date
    May 2001
    Posts
    24,066
    Default
    Looks like the YM Crash Test Boat, series II
    Next time, it'll all be different.
  6. #6
    Join Date
    Dec 2002
    Posts
    917
    Default
    Looks to me like they put in three big black rectangular sheets of carbon on the inside, and square bits of ?chopped up batten? on each bolt on the outside.
  7. #7
    Join Date
    Jan 2003
    Posts
    4,468
    Default
    Quote Originally Posted by tom_sail View Post
    The are certainly not built for comfort.Not many soft furnishings down below
  8. #8
    Join Date
    Jan 2004
    Posts
    1,005
    Default
    But when they do go quickly......wow....
    http://www.youtube.com/watch?v=rBQXt7QnnXk
    edited because it appears I don't know the tags for embedding a youtube clip after all...
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
