Results 11 to 19 of 19
05-04-12, 15:11 #11
Registered User
- Join Date
- Jul 2002
- Posts
- 27,506
05-04-12, 15:25 #12
Jeanneau Merry Fisher 805 For Sale. www.gooch.co.uk
05-04-12, 15:26 #13
05-04-12, 15:29 #14
Wasn't being rude or suggesting you are mean, we all know about budgets.
What i really meant was, changing to an external pump to save £50 wouldn't be practical as the external pump would cost much more than that. If yours is totally kaput, an external pump would be cheaper than £900 for a new one.Jeanneau Merry Fisher 805 For Sale. www.gooch.co.uk
05-04-12, 20:09 #15
Registered User
- Join Date
- Jul 2010
- Posts
- 34
No, that's fine, I know you're not, and I am really grateful for all the advice (you replied to my first post as well) as although I have stripped and repaired an engine it was many years ago (and I didn't have a bad back then either!) and it was a petrol engine that was in a car. I have no experience of marine diesels at all really and freely admit that I'm looking for shortcuts that I know are not ideal but will tide me over for the time being.
Anyway, thanks again for your help and I will see what I can do next time I have a chance to do some work on it
05-04-12, 22:10 #16
Registered User
- Join Date
- Apr 2007
- Posts
- 323
If you are going to fit an electric pump it would be advisable to wire it through a relay which is switched from the oil Pressure switch so it only runs when the engine is running or you may accidentally fill your exhaust up with water!
06-04-12, 17:50 #17
As has already been said, the price for the impeller at about £30 is fairly typical. The two seals are about £10 each which is a bit steep. However, fitting a complete new pump will cost far more than £50 and involve the risk of further complications.
The original Albin pump is an unusual and clever design as it is actually two pumps on the same shaft. The front one handle the raw water. The rear one circulates the fresh water on a fresh water cooled engine. On a raw water cooled engine it acts as a motor-drive bilge pump and there is a small bleed hole between the two pumps to stop it from drying out.
If you engine is fresh water cooled then you cannot simply fit one new pump as you suggest. If it is raw water cooled, do you plan to buy a replacement bilge pump too?
I think that it would be unwise to modify the engine just to "save" £50.Dave Seager
Weybridge UK
06-04-12, 17:58 #18
06-04-12, 18:14 #19
Having read the origina thread and this one, it sounds like you may be lucky if the pump seal is the problem as it sounds like the volume is too high and getting through to the rocker cover through the valve lifters which implies that water may be flowing into the combustion chamber ........ but I would definetly try the simple things first as the tend to be somewhat cheaper than the big jobs....
Regards, Alf
I've stopped drinking water .... I have seen what it does to the bottom of our boat!
"The only time you have too much fuel is when you're on fire."
You've asked a question about a saily boat on the Mobo forum
Bookmarks
