I have been attempting to earth the coupling but I don't like the idea of the silver impregnated rubber strip which is recommended as I can't see how it can provide a good contact. I attempted to use a copper braid with crimped ends connected to each side of the coupling but this failed part way through the season. I assume it must have fatigued due to vibration and centrifugal loads. Has anyone solved this problem.
Results 1 to 10 of 14
Thread: R + D Coupling Earth Bonding
05-04-12, 23:18 #1
Registered User
- Join Date
- Jun 2005
- Posts
- 189
05-04-12, 23:58 #2
Registered User
- Join Date
- Jul 2002
- Posts
- 27,506
Perhaps you have discovered why R&D suggest the rolled up silver impregnated rubber strip!
The alternative is perhaps MG Duff's "Electro Eliminator" or something similar. http://www.mgduff.co.uk/leisure-craf...s/electro.htmlLast edited by VicS; 06-04-12 at 00:04.
06-04-12, 00:07 #3
The way I electrically bridged the doughnut is by using a bit of stainless steel wool, culled from a pan scourer. Just stuff it in the centre of the couplings so it is against the metal strapsof the doughnut and Robert is your mother's brother.
"Beer is proof that god loves us and wants us to be happy" B. Franklin
06-04-12, 00:23 #4
Registered User
- Join Date
- Jul 2002
- Posts
- 27,506
06-04-12, 07:09 #5
Registered User
- Join Date
- May 2001
- Posts
- 1,092
I used the R&D suplied rubber strip it works fine, I check it with multimeter when boat is out of the water.
06-04-12, 08:47 #6
Registered User
- Join Date
- Jun 2005
- Posts
- 189
Any problems with corrosion. The straps in contact with the silver or stainless are just zinc plated steel. I would have thought the connection would need to be fairly low resistance to get full benefit from the anode.
06-04-12, 08:52 #7
Registered User
- Join Date
- Aug 2004
- Posts
- 1,975
My bridge is just a length of flexible copper wire with a ring terminal on each end.
I fitted it in 2004 and it's still there, I hope!!
06-04-12, 09:00 #8
Registered User
- Join Date
- Jun 2005
- Posts
- 189
What sort of wire and terminals. I tried a braid and standard yellow crimp rings. It broke after about 50 hours. I was thinking of soldering but it usually stiffens the wire too much. Maybe the braid was too flexible and moved too much.
06-04-12, 09:22 #9
Registered User
- Join Date
- Aug 2004
- Posts
- 1,975
I'd have to look to be certain, but IIRC, a short length of multi-strand insulated copper wire, around 10swg, with 10mm, (bolt size ) yellow sleeved terminals.
I usually pull the sleeves off, lightly crimp the terminal onto the wire with pliers, solder and refit the sleeve, the hot metal makes the sleeve more flexible. I find a small butane blow-lamp handy, the quick, localised heating minimises solder flow along the wire.
This bridge noticeably increased the rate of anode erosion, and the new propellor I fitted at the same time shows absolutely no sign of corrosion, unlike it's predecessor.
My 3-cyl. engine probably gives the coupling a fairly easy time.
06-04-12, 13:32 #10
Registered User
- Join Date
- Jun 2005
- Posts
- 189
Thanks earlybird thats very helpfull. I have just found two heavy duty 10mm terminals so I will try crimping and soldering this time.
Bookmarks
