Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    Jun 2005
    Posts
    191
    Default R + D Coupling Earth Bonding
    I have been attempting to earth the coupling but I don't like the idea of the silver impregnated rubber strip which is recommended as I can't see how it can provide a good contact. I attempted to use a copper braid with crimped ends connected to each side of the coupling but this failed part way through the season. I assume it must have fatigued due to vibration and centrifugal loads. Has anyone solved this problem.
  2. #2
    Join Date
    Jul 2002
    Posts
    27,675
    Default
    Perhaps you have discovered why R&D suggest the rolled up silver impregnated rubber strip!
    The alternative is perhaps MG Duff's "Electro Eliminator" or something similar. http://www.mgduff.co.uk/leisure-craf...s/electro.html
  3. #3
    Join Date
    Oct 2005
    Posts
    3,321
    Default
    The way I electrically bridged the doughnut is by using a bit of stainless steel wool, culled from a pan scourer. Just stuff it in the centre of the couplings so it is against the metal strapsof the doughnut and Robert is your mother's brother.
    "Beer is proof that god loves us and wants us to be happy" B. Franklin
  4. #4
    Join Date
    Jul 2002
    Posts
    27,675
    Default
    Quote Originally Posted by michael_w View Post
    Would it be possible to fit a spring in there? Seems so obvious that there must be some reason why not.
  5. #5
    davidwf is offline Registered User
    Join Date
    May 2001
    Posts
    1,097
    Default
    I used the R&D suplied rubber strip it works fine, I check it with multimeter when boat is out of the water.
  6. #6
    Join Date
    Jun 2005
    Posts
    191
    Default
    Any problems with corrosion. The straps in contact with the silver or stainless are just zinc plated steel. I would have thought the connection would need to be fairly low resistance to get full benefit from the anode.
  7. #7
    earlybird is offline Registered User
    Join Date
    Aug 2004
    Posts
    1,997
    Default
    My bridge is just a length of flexible copper wire with a ring terminal on each end.
    I fitted it in 2004 and it's still there, I hope!!
  8. #8
    Join Date
    Jun 2005
    Posts
    191
    Default
    What sort of wire and terminals. I tried a braid and standard yellow crimp rings. It broke after about 50 hours. I was thinking of soldering but it usually stiffens the wire too much. Maybe the braid was too flexible and moved too much.
  9. #9
    Join Date
    Aug 2004
    Posts
    1,997
    Default
    Quote Originally Posted by KAM View Post
    I'd have to look to be certain, but IIRC, a short length of multi-strand insulated copper wire, around 10swg, with 10mm, (bolt size ) yellow sleeved terminals.
    I usually pull the sleeves off, lightly crimp the terminal onto the wire with pliers, solder and refit the sleeve, the hot metal makes the sleeve more flexible. I find a small butane blow-lamp handy, the quick, localised heating minimises solder flow along the wire.
    This bridge noticeably increased the rate of anode erosion, and the new propellor I fitted at the same time shows absolutely no sign of corrosion, unlike it's predecessor.
    My 3-cyl. engine probably gives the coupling a fairly easy time.
  10. #10
    Join Date
    Jun 2005
    Posts
    191
    Default
    Thanks earlybird thats very helpfull. I have just found two heavy duty 10mm terminals so I will try crimping and soldering this time.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
