Thanks Steve!
We went down (against all forecast wisdom) on Saturday (even took the dog as we were not going anywhere), yes we had a few showers sat pm but then the sun would come out and dry everything off again. Didn't go anywhere but had a relaxing time, great weather Sunday am. We packed up about 1.30pm and as we did it started to rain, drove home up the A3 with great views of some lightening storms!
Couple of points of vague interest.
1. Dog spotted this, peering over the side she got all excited, so looked myself and a massive shoal of grey mullet. Now there are always lots of grey mullet around and often there are 3 or 4 in a group, but I kid you not to say that the shoal spread from one set of pontoons to the other, it was almost as if you could walk across them... there were thousands...!!
2. Mercury is starting to fill up a bit, not so many gaps as there were last year..
3. When you have a dog lying on the pontoon many more people speak to you...
Oh, and BTW, can't believe you are missing bank holiday, for godsake Steve, make sure you book 4&5th June off!!
Results 111 to 120 of 186
24-04-12, 13:08 #111
24-04-12, 13:50 #112
Sounds like you are getting there Gary, as always if you need ahand......
You only lose when you stop.
24-04-12, 13:53 #113
24-04-12, 13:56 #114
24-04-12, 13:58 #115
thanks
next challenge is getting the cas off the UJ's my cheap pair of mole grips aren't cutting it so going to buy a pair of Irvin Vice Grips later today and get them out with those hopefully... determined to get the UJ's out today so I can make progress getting the drive put back together.
Will likely be down this weekend if you fancy a beer
24-04-12, 16:57 #116
24-04-12, 19:43 #117
24-04-12, 20:03 #118
lols... I have a garage full of them for that very reason... bit of a cock up tonight actually.. put the end of Cross Bearing stem through the end of one of the caps as I'd not aligned the C Press up perfectly so it compressed against the press when pushed through, in fact, some of the surfaces of the UJ are at an angle which invites the clamp to slip a little... got the cross bearing out in the end but the insides of the cap are still in the holder had to chamfer off a sliver of metal from the end of a cross bearing stem with an angle grinder to get it out though as the casing from the cap got in the way.
Cracking on with getting the other caps off and will then focus my attention/wallet on buying another tool to get rid of the reminents of the cap.
pleased with progress so far and should hopefully have everything ready to rebuild by tomorrow and will do so when the new cross bearings arrive.
having a little break as I was getting in to the employ a BFH mindset with one of the bearing caps, will the bugga shift? will it 'eck
moving the caps back and forth with increasing amounts of 3-in-1 oil seems to work eventuallyLast edited by oGaryo; 24-04-12 at 20:05.
24-04-12, 20:03 #119
24-04-12, 20:22 #120
Bookmarks
