Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 73
  1. #21
    William_H is offline Registered User
    Join Date
    Jul 2003
    Posts
    7,441
    Default Engines
    I would always try to repair what you have however you are obviously thinking of options.
    I think an O/b in a well is horrible. It is difficult to remove to reduce drag and it gets in the way of cockpit floor space.
    I have an o/b on a bracket but then I don't use the engine anyway.
    One design around here called a Marauder 24 has a half a well at the transom. The engine actually mounts on a transom in a well inboard by about 50cms from the main transom. The main transom has a cut out in it.
    This puts the engine about 80cms forward of where it would be on a bracket so less pitching problems.
    It is easily tilted back and up to reduce drag.
    This works with an inboard mounted rudder. In your case I would consider building twin rudders either side of engine.
    You might consider simply mounting the engine on the transom which perhaps can be cut low enough for your short shaft engine.
    Just a few thoughts for your imagination. good luck olewill
  2. #22
    Yantlet's Avatar
    Yantlet is offline Registered User
    Join Date
    Nov 2011
    Posts
    272
    Default
    Let's face it the most economic way would be to just buy a rise and fall bracket and hang a long-shaft o/b on the back - job done! The Slug is such a stubby little boat that with a long-shaft you would have to have the bow underwater before the prop would be out of the water the other end. And in any case as you have always expounded If its that bad I wont be out! You can then remove The Beast and either not worry about it ever again,restore it or sell it.
    Green Bay Auckland New Zealand
    "Time And Tide Wait For No Man"
  3. #23
    Yantlet's Avatar
    Join Date
    Nov 2011
    Posts
    272
    Default
    I think this illustrates exactly what Dylan is talking about regarding resale values, you sure can get some good buys in the UK.
    http://www.andyseedhouseboats.co.uk/...hp?boatid=1282
  4. #24
    Niander's Avatar
    Niander is offline Registered User
    Join Date
    Jun 2003
    Posts
    1,207
    Default
    the engine starts and runs - stuck in forward
    but I can live with that
    So whats the problem then?
    just get an outboard with reverse for when you need it.
  5. #25
    Join Date
    Mar 2005
    Posts
    6,440
    Default unreliable
    Quote Originally Posted by Niander View Post
    I do have a Honda 2.3 on the back of the boat which is fine as a back up and for marinas -
    but it is not up to getting me through the rough stuff around some of the bars I have come across
    Wells, Deben and colne bar all got pretty horrible
    wells is a lulu and the channel that forces you at right angles to the breaking waves
    a bigger boat can suck up the punishment but the cresting waves fill the cockpit and shift the boat sideways
    and small boat needs to be turned bow in towards each breaker and then a quick turn on the back of the crest to make forward progress between the breakers
    the only way to do that with an outboard on the tsern is to vector it
    I would hate to be hanging over the transome vectoring outboards u nder such conditions
    I can't even contemplate the shame and derision heaped upon me on this forum should I end up calling out the emergency services because the beast has let me down.
    As I said earlier - it has cost me a lot of money, time and emotional trauma
    Dylan
  6. #26
    John the kiwi is offline Registered User
    Join Date
    Nov 2011
    Posts
    120
    Default nowell nowell the angels did sing!
    Why do people want to put OB s in wells?
    So much Cockpit space lost and so much drag! My boat had an over sized OB in well when i bought her. I tried an OB bracket and that was horrible. Hanging over the transom to change gear etc. So I hung it on transom as close to rudder as i could. I fabricated a linkage that turns motor with rudder.
    This is pin jointed and i remove it when tilting the motor. The swivel in the middle is for when i forget to remove it before tilting. I can steer from standing on cockpit seat with tiller extension which is handy in confined areas, and the prop never hits the blade. I can motor/sail with blade up or down, but with motor tilted, Ariel has a clean pair of heels, drag-wise.
    Stub tiller is used as the main tiller pivots to lift blade. Wish i had spent more time on aesthetics as after 2 seasons prototype looks like a permanent fixture! Pics show motor in well as per original and current arrangement.
    Attached Images Attached Images
  7. #27
    Join Date
    Oct 2001
    Posts
    2,621
    Default
    Well Well Well.
    I have a Snapdragon 23, with an outboard in a Well and am currently rebuilding the well.
    Firstly I must say that having a Well has had virtually no issues. The only concerns are that it saps a bit of cockpit space but to be honest, I think it would only be an issue with 4 in the cockpit and that the outboard leg needs some form of antifouling.
    Oh and the engine is bleedin' heavy, but that's not the Well's fault.
    The engine is a bit of a brute (10hp Honda 4-stroke) and that is supported by a 2 1/2 inch plywood supporting transom, which is bolted into the sides of the cockpit and through a thinner 3/4 inch plywood transom that makes up the inside 'wall' of the transom.
    I'm only redoing it as the cockpit floor was a bit 'Heath Robinson' so i'm replacing all the wooden parts.
    Fuel Tank sits in one of the cockpit lockers.
    Boat came to me that way so I've not experienced without but it seems to work for me.
  8. #28
    Niander's Avatar
    Join Date
    Jun 2003
    Posts
    1,207
    Default
    LIke that John!
    An outboard in a well is less likely to come out in a heavy sea and race the engine...nasty!
    its also closer to cockpit...a few important advantages
  9. #29
    Default
    Quote Originally Posted by dylanwinter View Post
    I have been on the look out for a small, safe, seaworthy, easily handled , short masted yacht with outboard in a well.
    Dylan
    I couldn't help thinking that you were describing my boat!
    Newbridge Coromandel.
    Expect lots of posts describing how a junk rig is no use to anyone. Mine got me from Lincolnshire up to the Tyne and back last year, might get a bit further this summer.
    Andy Seedhouse has a very original looking one for sale. It has a tabernacle and no standing rigging, so the mast can be dropped in 5 minutes and raised again just as quickly.
  10. #30
    northwind is offline Registered User
    Join Date
    May 2010
    Posts
    455
    Default
    One important consideration, especially if you are venturing up north is the availability of fuel.
    Getting hold of petrol (without a car) when in remote places will be a pain, I read in the PBO round britain book that diesel is easier to get hold of beside the sea than petrol in the remoter places in the highlands.
    D
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
