I once set 5 sails at the same time on my Arpege in the 70s. It is called good fun and learning about sail handling. You might also try a mizzen on a boat hook from one of the back stays and a spanker set below the boom.
Forget about all these purists and instruction books. Go for it. Choose a calmish day and enjoy but remember that you have to get them in again if the wind comes up.![]()
Results 11 to 17 of 17
Thread: Hanking on a sail to a babystay?
14-04-12, 16:01 #11
If you sail by the lee, eventually you will gybe.
15-04-12, 19:53 #12
[QUOTE=jerrytug;3483423]....... Bearing in mind she was definitely not designed to be rigged as a cutter [QUOTE]
Neither was my boat, but with the stay shifted to parallel the forestay and sails cut to suit she became a superb all-weather performer without the drawbacks of a Genoa.
You might find it worthwile to take a look at my album "A unique Pionier 10" (by clicking on "Krusty")Last edited by Krusty; 15-04-12 at 19:56.
15-04-12, 19:55 #13
16-04-12, 23:02 #14
17-04-12, 11:30 #15
Registered User
- Join Date
- May 2006
- Posts
- 844
Thanks for the further replies,that`s just what I had in mind Digbydog and Krusty! Brilliant! Your `babystays`l` certainly looks useful indeed on the pioneer cheers for the inspiration matey!
17-04-12, 17:14 #16
The sail was from a dinghy, I can't remember which one but not too large. I hanked the piston hanks onto the leeward backstay and lashed the boathook to the stay and to the foot of the sail. Lashed the clew to the end of the boathook as an out haul and had sheets which followed through the aft corners of the pushpit. I used the main topping lift as a halliard and a downhaul down to the rigging screw. It set quite well and the whole issue certainly caused a few comments on the river Blackwater.
17-04-12, 22:52 #17
Bookmarks
