Hi, the fuel gauge on my Bavaria shows nearly full when i turn on the ignition for the engine, but once the engine starts the fuel gauge shows empty. Does anyone have any advice on the cause of this![]()
Results 1 to 4 of 4
Thread: Fuel Gauge
14-04-12, 19:26 #1
Fuel Gauge
Loves Sailing, Fortunately no Garden
14-04-12, 22:26 #2
Registered User
- Join Date
- Feb 2007
- Posts
- 536
Sensor wiring reversed?
15-04-12, 14:38 #3
The fuel gauge does not know when the engine starts, so it sounds like a loose connection. Is the tank actually full? Troubleshooting can start at the sensor. Get a multimeter on Ohms range, and measure the resistance across the two terminals on the sensor - obviously disconnect them first. It should read somewhere between 5Ω and 300Ω.
[Later] Reversing the sensor wires make no difference.
By the way, as you have a Bavaria, see my signature.Last edited by nigelmercier; 16-04-12 at 14:09.
Nigel
FREE Bavaria Yacht Forum: www.bavariayacht.info
15-04-12, 19:33 #4
I had the same problem - when I put some diesel in the gauge went up....
Bookmarks
